Question about Tablets & eReaders
My irulu android tablet turns on and gets stuck the irulu introduction screen 7inch
  • 3940 Answers
SOURCE: my binatone homesurf tablet is stuck on the home screen and wont do anything can you reset it
Sounds like it needs a reset.
The Binatone Helpline is available from 9.00 am to 5.00 pm, Mondays to Fridays, please call0845 345 9677 for UK+491805938802 for EuropeAustralia customer service number 1300 768 112 or email to service@shriro.com.au India customer service number +91 7503011385 or email to assist@binatonetelecom.in
http://www.binatonetelecom.com/binaries/content/assets/binatone/products/android-products/homesurf-7/pdf/homesurf_7user_guide.pdf
The manual has very limited troubleshooting, so it looks like you'll need to call them.
Posted on Oct 25, 2011
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
jrosage
SOURCE: irulu tablet user manual
Can this tablet hook up to a printer?
Posted on Nov 20, 2012
TechyDrood
  • 2072 Answers
SOURCE: how do i use my 3g network on my irulu 10.1 tablet
  • Go to your mobile provider, I.E. Verizon, att, sprint and make sure you are paying for the 3G access.
  • I believe they also provide you with a sim card, this identifies your tablet to your paid account
  • Then go into settings and mobile networks and enable 3G
Posted on Dec 08, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
How do i reset my irulu tablet
hold volume up, power button and home button. If you get 10 months life out of an Irulu, you are lucky. Cheap Chinese entry level toy with no support.
  • How to reset your 7 inch irulu tablet - YouTube www.youtube.com/watch?v=FzqiP1hOZTs
    • BY SIMON PROSPER
    • 2 MIN
    • 62K VIEWS
    2014-08-03 · Video embedded · Want to watch this again later? Sign in to add this video to a playlist. This video was uploaded from an Android phone
  • How do I factory reset a iRulu Android tablet? The screen ... www.askmefast.com > Computers & Internet > Software > Tablet Irulu tablet reset to factory settings. My sis have forgotten her password for her ipro android tablet.i have tried to reset it to factory settings using power/volume ...
  • IRulu_SystemResets < Wikilearn < TWiki twiki.org/cgi-bin/view/Wikilearn/IRulu_SystemResets System Resets . There are two types ... This did not reset the iRulu to its factory configuration. ... Tablet PC Android User Manual--user manual for another brand of ...
  • Related searches for reset my irulu tablet
  • Jun 02, 2016 | Irulu 2014 7 inch Android Tablet PC with...
    Irulu Expro tablet. Where is the Bluetooth setting?
    iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 ...
    https://www.irulu.com/tablet/p-irulu-expro-x1plus-10.1-inch-quad-core-t...
    iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 Lollipop support Wifi OTG ... Bluetooth: 4.0 ... iRulu Google Android Capacitive Tablet PC(1) ... 1 Comments 0 or 0 people found the following review helpful .... Connect With Us.
    iRULU eXpro X2Plus series android 4.4 high-speed Octa Core
    https://www.irulu.com/tablet/p-irulu-expro-x2plus-series-android-4.4-hig...
    iRULU eXpro X2Plus series android 4.4 high-speed Octa Core Tablet 16GB ROM 10 points Capacitive IPS touch screen Bluetooth 4.2. $89.99 $179.99.
    Irulu Tablet - Android Forums at AndroidCentral.com
    Dec 26, 2015 | Tablets & eReaders
    Can't find camera flash on off
    forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
    Dec 18, 2012 - 24 posts - ‎21 authors
    Real 1G DDR3 Nand Flash 8GB Camera 0.3MPixels-Front Android ... Can't find apps as downloadable to such as ad card anywhere in google play. ..... Problem is, every time i reboot the tablet or the device is off then turned ... Irulu AX101 stuck on Irulu connecting my world, how ...
    Sep 20, 2015
    How do I change the camera view on an irulu tablet?
    Apr 13, 2015
    How do I keep my Irulu from turning on randomly?
    Sep 30, 2014
    Problems switching from front camera to back camera
    May 13, 2014
    More results from forums.androidcentral.com
    How to find your Chinese Tablet firmwar
    Dec 21, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
    Stuck on irulu screen
    Submit your question again so I understand what you mean exactly please....
    Apr 05, 2014 | Irulu 7" Touch Screen 2gb Android 2.3...
    Can't access Google Play store?
    Look at the date of your phone and see if it is up to date. It happens when your the date is not right.
    Jul 30, 2017 | Irulu 7 Inch Android 4.1 Jelly Bean...
    Tablet is stuck on the screen that says android
    You may have to reset the tablet to factory settings. This may be the only way. It will wipe all the data on it.
    To factory reset:
    1. Press and hold power plus volume up until an android menu appear 2. Use the volume keys to navigate and option key or power to select. 3. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
    Feb 04, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
    Irulu 7 instruction manual?
    i cant get my wi-fi work on my irulu tablet help please
    Aug 19, 2012 | Irulu 4g 7"google Android 2.3 Touchscreen...
    Tablets & eReaders Logo
    27 people viewed this question
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
