Question about Honda EG4000 Generator
Generator starts and runs for about 3 seconds then stops then restarts and stops.
Generator had been running for 3 hours with a/c and refrigerator and lights (on concession trailer)when we experienced a loss
the unit has gone into over load
The total power requirement has exceed the output of the generator
for example if the generator is a 2.500 kw or kva then it will generate well at 1.8 kva or kw but it will not run forever at 2.5 kva -kw
When a ac is running the power requirement will be constant on the generator and with the fridge as well then the load will be at the maximum out put of the unit.
when the fridge starts again the extra load will exceed the max out put of the generator and it will slow down ( lights dimming ) and eventually go into overload mode
have an accredited electrician calculate your maximum load requirement for an external power supply and then get a unit that is at least 15.. kva kw better that required
generally fridges use 1000watts , ac conditions will draw over 3000watts and any thing else adds up . I am guessing that your generator is only 2500 unit
Apr 12, 2015 | Northstar Electrical Supplies
What can make diesel engine to vibrate surdenly when the engine is running on load from a air compressor
When the compressor starts, initially there is a very large current draw by the compressor motor. Depending on the size of the generator and compressor motor, this could cause the generator to stumble for a few seconds, but this should smooth out within 3-5 seconds.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
1986 sei 1200 goldwing It will start from ignition on,fuel pump runs for a few seconds,fuel light goes out,every thing normal-no LED diagnostic lights.When it starts it will run for about 3-5 seconds &...
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Aug 03, 2009 | 1986 Honda GL 1200 Aspencade Gold Wing
Generator will start and run easy, then just die.
Check for loose wiring connections, especially at the run or kill switch. Generators vibrate a lot so it could be as simple as something loose.
Jun 15, 2009 | Electrical Supplies
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
It sounds like you are not producing any voltage. When you start your generator have a volt meter on the generator breaker to see if there is voltage present when the genset is running. Also, check you oil pressure switch, which is near the oil filter.
Apr 11, 2009 | Electrical Supplies
Commercial generator 20kv not working properly
Troubleshoot like this:
1 - With the generator control in Auto, jumper from terminal 3 to 4 on the control board. Generator should start without transfer switch doing anything. If it won't you have a bad controller board.
2 - If the Generator started, remove the jumper - controller is OK. Next go to the 1st transfer switch and find the remote start terminals. These will be the same wires that were connected to controller terminals 3 and 4 at the generator. Use your jumper wire to connect them and see if the generator starts, if not there is something wrong between the switch and the generator, probably a broken wire.
3 - Don't forget to check the other switch, the remote start terminals of the switches connect in parallel across controller terminals 3 and 4 so that either switch can start the generator.
4 - Each switch should have some sort of a test button/switch, power down as much of the building as you can, then run the test function of each switch one at a time. Don't stand directly in front of the switch while you do this.
Nov 20, 2008 | Electrical Supplies
Honda EG4000 Generator Logo
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
