What color wires on a Balance CM2015 go to which pin on a D sub connector?
    Genius:
  • 1,018 Answers
A "Balance CM2015" is a color monitor, not a printer. Why do you want to make your own cable? Just go to local store and purchase a 9 pin video cable. Don
Posted on Jun 14, 2009
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
Which color wires go to the pin on a d-sub connector for a logitect x530 speaker system
Connect the d-sub connector plug (the VGA cable,probably black colored) into the subwoofer.
Oct 12, 2011 | Logitech X-530 Computer Speakers
Hello, my video card is nvidia geforce 6150 le and the red color is gone, thank you for your help.
You should be able to adjust the color balance for the card. There will be software on your machine that allows you to set the color balance and other things. Usually there is at least some red However if the red is totally gone then it could be a problem with the cabling/connector between the desktop and the monitor, like a loose pin or wire. It is possible that it may be the monitor that has the red out. So first check your connections and your color balance. If that seems ok then try another monitor before you go further. If a different monitor has the same problem (with different cabling too) then you will know.
Aug 16, 2011 | HP Compaq Presario SR2020NX PC Desktop
Brand new (literally...just purchased today) LG E2350V remains in D SUB Power Save Mode as soon as the computer is booted up. Have attempted numerous suggestions, none solve the issue. Please do not...
First thing to do is try another monitor on that computer, because it actually sounds like the computer isn't sending a signal to the monitor.
The next thing to look for is to unplug the monitor from the PC and also from the monitor (assuming it detaches from the monitor) and look inside the sub-D shell for a bent pin.
If one of the pins IS bent over, be VERY VERY careful straightening it, because they break easy once they've been bent.
If you do break a pin, yuo will have to replace the Sub-D connector.
If you do have to replace the connector, here's the pin-outs and wire colors.
http://www.theavguide.co.uk/view_page.php?page=18
The connectors you can (or used to be able to) buy all over the place.
Jul 27, 2011 | LG Computers & Internet
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I need the display driver cm2015
http://members.driverguide.com/driver/detail.php?driverid=564775
I'm not sure where you found your driver, but this is from another website, hope itworks
Dec 13, 2008 | Balance CM2015 15" LCD Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
I just bought a cat5 cable and to covert to vga male and famle head . But i have no clue which pins to solder together because cat5 has 8 cores , while vga has 15 pins or so can you help
I'm not exactly sure how you expect to use a Cat 5 cable for VGA video (Takes 12 wires last time I looked) but here is how the cable connectors are wired
SVGA (35-37 KHz - 800x600) 15 pin sub D:
6
1 Red (Analog) 6 Red Return 11 (ID0) GND (Color) 11. . . 1
2 Green (Analog) 7 Green Return 12 (ID1) NC (Color) . . .
3 Blue (Analog) 8 Blue Return 13 Horzontal Sync . . .
4 Not Used 9 Not used 14 Vertical Sync . . .
5 Ground 10 Ground 15 Not Used . . .
15 10 5
Jun 22, 2008 | Computers & Internet
YELLOW SCREEN
hi there, check your video cable, most of it has a broken cable. ty
Dec 26, 2007 | Balance CM2015 15" LCD Monitor
29 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
