My Fujitsu laptop shows a string of text ''HNZAC'' when I press ''A''. Also has a problem with pressing S deletes randon test and show =7/,TS]. Can you let me know how to solve this problem please. Thanks, Mark
Tip
Fast program panel on windows
did you now that on windows you can make your all program panel show very fast than usually.
1. press the start button
2. find the menu called Run
3. the panel run will show up
4. type regedit and enter
5. and the registry editor will show up
6. press button ctrl + F on your keyboard
7. panel Find is show
8. type " menushowdelay " without space then press enter
9. after the menushowdelay edit strings found double click
10.change the number usually is 400 change with 0 or 1 then press ok
11. close all panel.the you can try the different from u all program menu on your windows
on Apr 09, 2010 | Computers & Internet
My web cam shows black also in camera test which is build in ah530(fh13ff-238)
Go to bios setup by pressing f2 and check that the "internal camera" is enabled.
Regards
Mar 07, 2015 | Fujitsu LifeBook AH530 NoteBook
DNS server or whatever...
Check your firewall is turned on or not.
Hold down the Windows key and press R. (This will open the Run dialogue.)
  1. Type "cmd" and press Enter. (This will open a command prompt.)
  2. Type "ipconfig /flushdns" and press Enter.
  3. Type "ipconfig /registerdns" and press Enter
  4. Type "ipconfig /release" and press Enter.
  5. Type "ipconfig /renew" and press Enter.
  6. Type "netsh winsock reset" and press Enter.
  7. Reboot the computer.
May 08, 2013 | Fujitsu Siemens Computers & Internet
My System Fujitsu Siemens Scaleo P cannot boot windows and doesn't proceed after display of Fujitsu Siemens Logo (Where it says Press F2 to Enter Setup).
I would take it back to the place of purchase, it is clear the window installation was not completed, a manufacture oversight.
Jun 18, 2012 | Fujitsu LifeBook AH531
My laptop shows no life when I press the power - Fujitso A6110 nb
I would remove the battery from the laptop for a few minutes and see if that makes a difference. When you plug the laptops power adapter into the laptop, do you see any lights come on.
You can take your power adapter to Radio Shack and they will test it for free. The most common problem is the adapter going out and your laptop is completely drained and will not start at all. A worse problem is the input jack on the laptop that the adapter plugs into is loose/bad. If that is the issue, you are looking at a big repair.
Jun 01, 2010 | Fujitsu LifeBook A6110 Notebook
I need to mass delete my text messages
hello,
If you want to mass delete your Text...from either inbox or any other folder... open the folder eg. Inbox press options then scroll to mark and mark all, then press option again and delete, you will delete everything there...
Nov 05, 2009 | Nokia E71x Cell Phone
Fujitsu amilo laptop
Try making sure your 'num lock' is off and if that doesn't work, try holding fn while pressing the key.
Mar 28, 2008 | Fujitsu AMILO M-6500 Notebook
Disc error
1. Power up unit with no disk in the tray
2. After "no disc" shows on the front display, press PAUSE on the remote
3. Press in order: 1, 4, 7, 2 on the remote (short keypresses). A new screen will show up, EEPROM settings with a green background
4. Write down the EEPROM string for backup/restore purposes in case you screw up. My string was 55 53 00 45 02 55 64 FF (compare with the default string of the 312, which is 55 53 00 45 14 55 64 FF).
5. To enable VCD playback, move the cursor to the "45" (4th group of characters from the left; use the remote up/down arrows to move right/left) and enter "46" or "47" instead, then press ENTER to commit
6. To enable SVCD playback, move the cursor to the "64" field (second from the right) and enter "FE" instead. To enter "F" press "6" on the remote and keep pressed. To enter "E" press "5" on the remote and keep pressed. After you're finished entering "FE" press ENTER on the remote to commit
7. Press PAUSE on the remote to exit the EEPROM screen
8. Power off, then power on again the player
9. It now plays SVCDs and/or VCDs depending on the codes you entered.
The final EEPROM strings with both VCD and SVCD enabled are:
55 53 00 46 02 55 FE FF and
55 53 00 47 02 55 FE FF
(either works)
NB the replacement of 64 by FE was in the past wrongly labeled as Macrovision hack. That's not true. What it really does is enable SVCD playback. If you only do the #5 above, you'll only get VCD playback. If you only do the #6 above, you'll only get SVCD playback. If you do both, you'll get VCD and SVCD playback.
(SVCD playback was especially important to me because I have several hundreds of them - mostly TV shows recorded on my TiVo, then exported to the PC and converted to SVCD)
The other hack for the DVB-312 also works on the 412 (see the configuration screen):
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
The info showing on that screen for the DVB-412 is:
Model: Zenith ZV8020001
Region: 1
Chip ID: M3355A-B
Servo ver: S101_43180
Microcom ver: V1.50A MP
PROM: 55 53 00 45 02 55 64 FF
Factory reset... done...
(the PROM I listed above is before the VCD/SVCD hack)
Aug 16, 2007 | Zenith DVB412 DVD Player
Computers & Internet Logo
165 people viewed this question
Alun Cox
David Payne
David Payne
