Question about Sunpak PlatinumPlus Ultra 7000 2-in-1 70" Tripod and Monopod
Cannot make camera fo up and down vertically
Cannot make tripod go up and down
I have a slik pro series 400 dx tripod, however i have lost the vertical tilt handle and wondered if spares are available
Your best bet is probably either Ebay, or the manufacturer. You may get lucky with a tour of your local camera stores, especially those that deal in pre-owned gear.
Mar 30, 2016 | Slik Photography
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
Digipower TP-TR62 manual needed
The handle probably operates the pan and tilt operations, and the head rotates through 90 degrees for vertical shots. The QR plate screws into the tripod socket on the base of the camera, then clips to the tripod head.
Nov 11, 2017 | Digipower Tp-tr66 3-way Panhead Tripod...
How do you properly attach the camera to the optex t465 tripod...there was no manual to go in...i want to make sure it's secure so i can have the camera vertical ...second question...i seem to have it...
Hi Julie.... These tripods are often a wee bit difficult to tighten down. I use a pair of common pliers to snug down the thumb screws to be sure the tripod stays put. Joe
thanks for choosing Fixya!
Dec 01, 2010 | Photography
Camera slips on tripod
Try cutting cork(available from local harfware store and gluing that to head. Be sure to cut precisely and don't forget about hole in center fot mounting post.
Jan 18, 2010 | Slik U-212DX Tripod
Nikon D40 vertical focus problem
Make sure the camera is using the appropriate focus sensor.
Does the problem occur when you focus manually?
Are you handholding the camera? Many people don't hold the camera as steady when holding it vertically. Try putting the camera on a tripod or other steady surface and see what happens.
Jun 11, 2009 | Nikon D40x Digital Camera
Knob missing for Miranda M800 Tripod (portrait Flip plate axes)
i have a miranda m-800 tripod no longer needed it has a knob broken but i still poses it can this help paul pjw6@talk21.com
Jun 04, 2009 | Slik U-212DX Tripod
Tripod problem
If you twist the panning arm on most tripods this usually locks the position.
Dec 11, 2008 | Victor APOLLO 2800 Tripod
SLIK 512QF tripod
Carole31,
I have the same tripod, and the screw shown in the photo you posted is to lock down the rotation of the tripod's head, i.e., what a video camera uses to pan (horizontally) across a scene. The large knob is used for the same in the vertical direction (up and down motion).
Jun 12, 2008 | Slik Photography
Missing plate to attach camera
I also have the same problem. I lost the plate fo my kalmar camera tripod? Did you find the source of it?
Mar 16, 2008 | Kalimar V-20S VIDEO TRIPOD
Sunpak PlatinumPlus Ultra 7000 2-in-1 70" Tripod and Monopod Logo
35 people viewed this question
Top Sunpak Photography Experts
Andrew Taylor
Andrew Taylor
richie46
Jay Plesset
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
