Question about Panasonic Toughbook CF-30 Notebook
TOUCH PANEL CONFIGURATION
DOES NOT WORK
My touchpad will not turn on. I have tried power reset with power plus center and tried reloading website too avail - nothing works I even tried a new battery - nothing... Any suggestions???
The touch pad of laptops can be disabled by a sequence Fn+Fx key. On my Toshiba it is Fn+F9. It can also be disabled/re-enabled from the touch pad configuration panel.
Oct 07, 2013 | Dell Inspiron 1545 Notebook
Touch panel won't function.
You may try reinstalling the firmware and configuring afterward. If this does not work the touch panel may be defective.
I will see if I find a download and further info.
May 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
Apr 16, 2013 | Lexmarkr X646E Multifunction Printer -...
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Touch screen do not work when touch on any icon
Your might need touchscreen configuration. Please follow the below solution.
If you are asking about the touchscreen of your desktop PC then I would suggest you go to control panel and look for ELO Control Panel where-in you will be guided to touch three targets on the screen. Then Verify the touchscreen if it is working and aligned properly. If you need to align further then go back to the ELO control panel and repeat the process.
Jul 16, 2011 | Computers & Internet
My scroll keys at the touchpad of my laptop won't work but the touchpad is working..
Have you tried going into the control panel to check the settings.
1. click on the start menu then on the right side of the panel click on control panel.
2. Go to the mouse Icon/Description then click on the advanced settings tab at the top far right.
3. You should find touch pad settings in here that will allow you to activate or deactivate the scroll functions or at the very least allow you to reset the settings to their default configuration.
Apr 23, 2011 | Computers & Internet
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
I dont want to be able to select something just by touching the little pad, i want to hafta left click, I'm constantly accidentally selecting something, just by touching it.
You can adjust your keyboard and the touch pad , controls with the adjustments in the menu for mouse and keypad options.
Also you can use the personal settings to get this right for your touch , adjusting the sensitivity accordingly
Sep 24, 2010 | Computers & Internet
Acer Aspire 5315 Touch pad problem
go to the control panel, mouse configuration , and try to turn on the touch pad
Aug 30, 2009 | Acer Aspire 5315 Notebook
Touch pad
config for touch pad is in control panel,mouse.
Jan 10, 2008 | Acer Aspire 5100 Notebook
Panasonic Toughbook CF-30 Notebook Logo
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
