Question about NEC Computers & Internet
Driver to the touchscreen model nec lcd 2070nx
2 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: I have a NEC Mutisync
it should be possible to take the cover off and fix your self with some contact adhesive like no more nails (etc) as the switch itself does not appear faulty this should work fine..
Posted on Aug 03, 2010
NEC 40 in. LCD TV
You will first need to identify the LCD panel model # to your set. There should be a sticker on the back of the LCD panel assembly stating the panel model #.You will have to take the back cover off to expose the back of the LCD assembly. Do not make the mistake in ordering a replacement panel based off of your TV model # alone !!! Many TV manufacturers will use multiple panels in the same model series. Once you have your LCD panel model #, you can try Ebay or just google the LCD panel model #. If there are parts dealers with the panel, google should find them for you. Hope this helps
Sep 03, 2012 | NEC 40 in. LCD TV
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
I need the disk to download th acer lcd toch screen to my new computer
You can download the drivers for the Touchscreen Monitor directly from the Acer website: Acer Support
Select "Monitor" from the Product Family list and select the correct series and model number which should be on the back of the monitor.
After you download the correct driver file, right mouse click on the file and "Extract" the contents. Then you can run the installation setup. Follow the prompts and reboot if needed.
Happy Computing, Myridom
Mar 05, 2011 | Acer 23" HD LCD Touchscreen 4GB RAM 1TB...
I have a NEC Mutisync LCD 2070NX monitor & the On-Off switch is "loose" making it difficult to turn the monitor off & on. Where can I go to get it fixed or would the cost of the repair be too...
Aug 03, 2010 | Computers & Internet
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
How do you flip the screen on this lcd computer so it's side ways
Nov 21, 2008 | NEC 1560V+ 15" Flat Panel LCD Monitor
Nec lcd1560v+
http://www.necus.com/support/ go down to where it shows drivers and software, choose NEC MultiSync LCD ...
Download the NEC LCD monitor installer and run it, NEC shows your monitor supported by this software. :)
Feb 11, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
35 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
