Question about Humidifiers
Humidifier problem keeps reading check filter
Why ismy Essick humidifier registering over 20 on the humidity level. I have changed the filters several times using high end filters?? I also have wet the filters
Sorry to ask, for clarification is this a dehumidifier or a humidifier? Do you want to add water to your air or take water out of your air. A reading of 20 for a humidifier sounds pretty good to me. I didn't know there were filters on a humidifier, I thought most of the time you just filled the tank with distilled water, it got heated and vapor came out. I guess a filter to keep airborne bacteria from floating into the water tank would make some sense, maybe a water filter to pre-filter the water going into your humidifier, but I don't think any filter is your problem. If you are trying to remove water from your air, then a dehumidifier is needed and you just have to empty the tank when it's full.
Feb 19, 2015 | Essick Air Humidifiers
CF is displayed on my humidifier...what is that?
Check Filter Indicator
The ability of any humidifier to efficiently supply humidity output relies heavily on the
condition of the filter. As the filter loads with impurities it gradually loses its wicking
capability. When this happens, moisture output is reduced and the humidifier has to work
longer to satisfy the selected setting. This humidifier has a check filter reminder timed to
appear after 720 hours of operation. When the Check Filter (CF) message is displayed,
disconnect the power cord and check the condition of the filter. If a build-up of deposits or
severe discoloration is evident replace the filter to restore maximum efficiency. The CF
message is reset when the humidifier is plugged back in.
Mar 05, 2011 | Bemis 826 800 Humidifier
How far do I need to open the water value to keep the filter wet but not dripping on my cellar floor ?
Sorry to read about your problem, I hope this helps you out.
you have a defective water inlet valve, leaking in water, or you water full sensor is defective.
you should be able to keep the water all the way open, with no problem.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Aprilaire 550 Humidifier
How to change from summer to winter
Can you give a little more info? Usually depending on where you live, people use de-humidifiers in the summer and humidifiers in the winter. If you need a humidifier year around, there should be nothing you need to do uther than filter cleaning and checking the water valve and cleaning the pan of mineral deposits. Depending on your water, you might need to pour a cup of limeaway in your pan and let it run for a couple hours. Then drain it, flush it, and let it keep running.
Sep 28, 2010 | Aprilaire 600 Humidifier
I have two questions. How do I properly clean my humidifier and recently it has started coating my furniture with a white powdery film. Why has it started that?
there is some cleaning tablets you can use periodically called protec beads ... cleaning can be done using high acid vinegar soak .. then hydrogen peroxide can be used on any mold .. this unit as well as ultrasonic type models will put out calcium dust if your water has calcium added or is hard water .. calcium is often added to water to give it a good taste .. one way to keep the unit clean for a long time is to use only distilled water .. and make sure there is no calcium added .. (read the small print on the container) .. its hard to clean the fan chamber in this unit .. lots of people complain about the dust .. the wick/filter type humidifiers dont put out dust but the calcium does accumulate on the wick/filter .. so you have to change that frequently (6-9 weeks) .. yours doesnt have a wick but still needs cleaned regularly ..
Sep 26, 2010 | Vicks V4500 1 Gallon Humidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
I READ SOMEWHERE THAT YOU COULD SOAK THE FILTER IN A SOLUTION WITH VINEGAR TO GET RID OF THE ORANGE COLOR AND THE HARDNESS WILL THIS HELP OR SHOULD I KEEP BUYING A NEW ONE FOR 9.00 ????
I SOAKED THE FILTER IN 1 C OF VINEGAR TO 1 GALLON OF WATER OVER NIGHT AND ITS NOT HARD ANYMORE BUT IT IS STILL ALITTLE ORANGE. SO I AM GOING TO TRY TO REUSE IT....
Nov 01, 2009 | Honeywell QuietCare HCM-630 Humidifier
How do I clean my hunter humidifier 33201? the filter blocks have white calcium? built up. I have sick kids and want it to be clean and running properly.
Soak the filters in a solution of 8 oz of white vinegar per gallon of water for about 20 minutes once per week and rinse well.
Better yet, do this once every 2 weeks, and on the off weeks soak the filters in a beach and water solution (rinse well) to keep the mold and bacteria growth from becoming a problem. I also add about a teaspoon of vinegar or a teaspoon of bleach (one or the other, not both at the same time) to the water when I fill the tank.
That helps keep the calcium scale from forming and it keeps the unit itself MUCH cleaner.
Oct 13, 2009 | Hunter 33201 Humidifier
No manual for Bonaire humidifier BCM 4510-U
If someone put it togetherm you can take it apart.
See if the dicharge grill slides up and the bottom vcan be pulled out like a window screen. If so, ,other panels may also do so in order to access the internals, Unplug unit when in the water or around fan. Do not run unit without panels in place. Any fan cleaning use something like 409 spray and rinse off with a spray bottle also. Keep water out of all and any electrical. Rinse and leave no cleaner in humidifier to be mixed with misting. Good Luck
May 17, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Water runs out of humidifier drain line constantly(rushes out)
Most modern humidifiers use a constant drain to flush mineral deposits, and to keep the water fresh at all times. This keeps the unit from holding standing water. This keep the water fresh and prevents mold spores from infesting the air in your home.
HVAC Teacher
Jan 27, 2009 | General Filters 1099-LH Humidifier
Humidifiers Logo
26 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
