Question about Toys
Freightliner codes Brake Wheel Sensor Axle 2L Open 136s003 05
Abs light is on all the time sometimes I get a code
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
Feb 11, 2015 | Freightliner Columbia & Century Class 120...
Remove rear wheel on 2012 flhtc harley
To remove a 2012 TOURING rear wheel FIRST remove the saddlebags, then raise the wheel with a suitable lifting device and rotate the wheel and inspect the wheel bearings. THEN remove left side muffler, on models equipped with low profile shock absorbers (FLHX, FLTRX), remove the left side lower saddlebag support rail and if ABS equipped remove the cable strap to releasethe rear wheel speed sensor cable from the rear brake hose and at no time ever left any magnetic force field exist or be close to the speed sensor or it will be ruined, remove the rear brake caliper but do not disconnect the brake hose, set the brake caliper on the passenger footboard or otherwise appropriately support it, remove the E-clip from the groove at the end of the axle, hold the weld nut on the left side of the axle and loosen the cone nut on the right side of the axle using an AXLE NUT TORQUE ADAPTER available from JIM's or H-D (HD- 47925), remove the cone nut and the adjuster cam from the axle, rotate the weld nut on the left side of the axlecounterclockwise until the wheel is loose, remove the axle from the left side of the motorcycle, catch all of the external spacer(s), caliper bracket, and rear wheel speed sensor (if ABS equipped) as the axle is removed, remove the caliper bracket from the anchor weldment on the rear fork, move wheel forward enough so that you can and slip the drive belt off of the compensator sprocket, if needed remove the brake disc from hub and be careful that the drive sprocket does not fall off and get damaged as you remove the wheel from the bike, mark the wheel and the disc for re-installation in the same orientation.
To install a 2012 TOURING rear wheel you will need FASTENER TORQUE VALUEs. The brake disc (rear) screws are 30-45 ft-lbs 41-61 Nm; (Do not re-use brake disc/rotor screws because re-using these can result in torque loss and always reinstall a brake disc in its original orientation); the rear axle cone nut (preliminary - 15-20 ft-lbs 20-27 Nm) (Final 95 to 105 ft lbs 128.8-142.4 Nm ) ; Brake caliper (rear)mounting fasteners 43-48 ft-lbs 58.3-65.1 Nm. If the brake disc was removed from the wheel ALWAYS reinstall it in the same orientation with the wheel as when it was removed and ALWAYS use NEW attaching screws and tighten them in a crosswise pattern to 30-45 ft-lbs (41-61 Nm), verify that the sprocket is square to and fully seated in the bowl area of the wheel, place the wheel into the rear fork with the drive sprocket installed, install the belt over the drive sprocket and then slide the wheel back to take up the slack, seat the brake caliper bracket on the anchor weldment of the rear fork, apply a light coat of wheel bearing type grease (H-D suggest silver anti-seize compound but this technician finds almost all seized, corroded axles were lubricated thus so do as you feel best) to the axle to the bearing bores and to the bore of the spacer sleeve, slide the axle through the left side of rear fork, the thin external spacer, the sprocket and into the wheel hub out the other side of the wheel hub and through the rear wheel speed sensor if ABS equipped and if ABS equipped ensure that the grooves on the external spacer, or index pin on the rear wheel speed sensor are on the outboard side or through the thick external spacer if not ABS equipped, the brake caliper bracket, and the right side of the rear fork, rotate the axle so that the flat on the threaded end is topside and with the adjuster cam section forward, install the adjuster cam on the right end of the axle, apply a light coat of SILVER GRADE ANTI-SEIZE (H-D Part No. 98960-97) to the inboard side of the cone nut but NOT the threads, install the cone nut on axle finger tight only, if ABS equipped route the speed sensor cable forward and outboard of the brake caliper bracket, continue forward following the top of the rear fork, rotate the speed sensor in a counterclockwise direction until the index pin makes contact with the brake caliper bracket, tighten the cone nut to a preliminary torque of 15-20 ft lbs (20-27 Nm), install the brake caliper and tighten its screws to 43-48 ft-lbs (58.3-65.1 Nm), secure the rear wheel speed sensor cable to the brake hose with the conduit clip located approximately 1.25 in. (31.8mm) in front of the brake hose crimp, adjust the drive belt using a belt tension gauge, final tighten the cone nut to 95 to 105 ft lbs 128.8-142.4 Nm, install a new E-clip with the flat side out in groove on the right side of the axle, on models equipped with low profile shock absorbers, install the left side lower saddlebag support rail, install the left side muffler and tighten its fasteners to 96-144 in-lbs 10.9-16.3 Nm,depress the rear brake pedal a number of times to set the brake pads properly against the brake disc, install the saddlebags and THEN road test the vehicle.
May 28, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
Remove rear wheel from 008 streetgide
To remove a 2008 Touring rear wheel FIRST raise the bike with the rear wheel off the ground, remove the saddlebags, inspect the wheel bearings, remove the left side muffler,on (FLHX) models equipped with low profile shock absorbers the remove left side lower saddlebag support rail, if ABS equipped cut the cable strap to release the rear wheel speed sensor cable from the brake hose to the brake caliper, remove the two socket head screws to release the brake caliper from its bracket, remove the brake caliper from the brake disc, pry the inner and outer brake pads back for additional clearance as necessary using a stiff putty knife with a wide thin blade to avoid scoring or scratching the brake disc, set the brake caliper on the passenger footboard, remove the E-clip from the groove at the end of the axle, loosen the cone with an AXLEfNUT TORQUE ADAPTER available from JIMs or H-D to get up between the axle nut and the right side muffler, remove the cone nut and adjuster cam from the axle, rotate the weld nut on the opposite side of the axle in a counterclockwise direction until the wheel is loose, use a soft metal drift to tap the axle towards the left side of motorcycle and catch the external spacer(s) (noting their place and orientation for reinstallation), pull the axle free of the rear swingarm, the caliper bracket, the rear wheel speed sensorf(if ABS equipped), and the wheel hub, keeping the ABS wheel speed sensor and ABS encoder bearing away from al magnetic fields such as magnetic parts trays, magnetic base dial indicators, alternator rotors, etc etc to avoid destroying them, remove the caliper bracket from the anchor weldment on the rear swingarm, move the wheel forward and slip the belt off from the compensator drive sprocket, hold onto the compensator drive sprocket while removing the rear wheel so that the isolators will not fall out, if necessary, remove to remove the brake disc remove the five fasteners and release the disc from the hub after marking the disc and the hub for re-assembly alignment in their original position.
To install a 2008 touring rear wheel FIRST reinstall the brake disc in its original orientation if it was removed and tighten the fasteners alternatively to 30-45 ft-lbs (41-61 Nm), ensure that the compensator sprocket is square and fully seated in its proper position, put the wheel into the rear swingarm and slide it forward and put the belt over compensator sprocket and then move the wheel back to take up the slack in the belt, install the caliper bracket on the anchor weldment of the rear swingarm, apply a light coat of wheel bearing grease onto the axle, the bearing bores and the bore of the spacer sleeve, insert the axle through the left side of the rear swingarm, the thin external spacer, and the rear wheel drive compensator sprocket into the and through the wheel hub left side and out the right side, through the rear wheel speed sensor (if ABS equipped) (the grooves on the external spacer, or index pin on the wheel speed sensor (if ABS equipped), are on the outboard side) or the thick external spacer if not ABS equipped, the caliper bracket, and the right side of the swingarm, rotate the axle so that the flat on the threaded end is topside and then with the thumb down and the cam forward install the adjuster cam on the end of the axle, avoiding contact with threads apply a thin film of LOCTITE ANTI-SEIZE lubricant to the inboard side of the cone nut, install the cone nut on the axle finger tight, obtain torque wrench with 1/2 inch drive head and the AXLE NUT TORQUE ADAPTER, install the torque adapter perpendicular to torque wrench ONLY or applied torque will be inaccurate, insert the tool up between rear wheel and the muffler and onto the cone nut, verify that the adjustment cam just contacts the weld nub on both sides of the swingarm (if necessary, push the wheel forward somewhat to do this), if ABS equipped route the sensor cable forward and outboard of the caliper bracket and then continue forward with it following the top of the swingarm, rotate the wheel speed sensor in a counter-clockwise direction until its index pin makes contact with the caliper bracket at its proper contact point, tighten the cone nut to 15-20 ft-lbs (20-27 Nm), properly position and install the brake caliper, align the holes in the caliper with the holes in the caliper bracket install the two socket head screws and alternately tighten them to 43-48 ft-lbs (58.3-65.1 Nm), install a new cable strap 1.25 in. (31.8 mm) in front of the brake hose crimp capturing the rear wheel speed sensor cable and brake hose together, using a belt tension gauge adjust the drive deflection to FLHR/C 3/8-7/16 inches or 9.5-11.1mm; FLHT/C/U FLTR FLHX 1/4-5/16 inches or 6.4-7.9 mm at the loosest spot in the belt, holding the weld nut on the left side of the axle tighten the cone nut to 95-105 ft-lbs (128.8-142.4 Nm), loosen it nut one full turn, retighten it to 95-105 ft-lbs (128.8-142.4 Nm), recheck the belt deflection, install a newE-clip in groove on right side of axle with the flat side out, on (FLHX), models with low profile shock absorbers properly install and torque into place the left side lower saddlebag support rail, install left side muffler, verify that the exhaust pipes are in alignment and do not contact the vehicle frame or mounted components, tighten the TORCA clamp to 45-60 ft-lbs (61-81 Nm), pump the brakes to position the pad against the brake disc, install the saddlebags and road test the motorcycle for proper operation.
May 05, 2014 | 2008 Harley Davidson FLHX Street Glide
How do i test the rear abs sensor on a 2007 tacoma
there is a good chance that the wire for the sensor has an internal break, this can happen if the axle drops down or the brake calipers falls down. Replacing the wire from the sensor to where it connects to the harness should fix this.
Jan 27, 2018 | 2005 Toyota Tacoma
How to install rear struts on a 1999 llexus
Lexus Car ES, IS, LS 1998-06
Coil Spring Rear Suspension
Print
Hub & Bearings
Adjustment
Check the backlash in bearing shaft direction and the axle hub deviation. Maximum for backlash should be 0.0020 in. (0.05mm) and for axle hub deviation 0.020 in. (0.05mm).
Fig. Checking wheel bearings for excessive play
NOTE The rear wheel bearings are non-adjustable. If the wheel bearing is out of specifications, replace the wheel bearing.
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Raise and safely support the vehicle.
  3. Remove or disconnect the following:
    Rear tire and wheel assembly Rear stabilizer link Rear axle shaft nut Rear disc brake caliper and disc Speed sensor Parking brake assembly at the wheel hub No. 1 and 2 upper control arm assembly No. 1 and 2 rear suspension arm assembly Toe control link Rear axle from hub assembly using a plastic hammer No. 2 rear wheel bearing dust deflector using a screwdriver 4 bolts and rear axle hub and bearing assembly from the axle carrier assembly
To install:
  1. Install or connect the following:
    Hub on the carrier and tighten the bolts to 52 ft. lbs. (70 Nm) No. 2 rear wheel bearing dust deflector using a screwdriver Rear axle into hub assembly No. 1 and 2 upper control arm assembly. Torque the new nut to the No. 2 rear upper control arm to 52 ft. lbs. (70 Nm). Temporarily tighten the No. 1 arm bolt. No. 1 and 2 rear suspension arm assembly. Temporarily tighten. Toe control link. Torque new nut to 52 ft. lbs. (70 Nm). Rear stabilizer link. Torque to 20 ft. lbs. (27 Nm). Parking brake assembly at the wheel hub Rear speed sensor Rear axle shaft nut. Torque to 214 ft. Lbs. (290 Nm) and stake the nut with a chisel and hammer. Rear brake disc and disc brake caliper
  2. Adjust the parking brake.
  3. Stabilize the suspension as follows :
    1. Install the wheel(s).
    2. Lower the vehicle and bounce it up and down several times to stabilize the rear suspension.
    3. Raise the vehicle.
    4. Remove the wheel.
    5. Jack up the rear lower suspension armplacing a wood block in between. Apply a load to the suspension so that the lower suspension arm is plkaced in a horizontal position.
  4. Fully tighten the No. 1 rear upper control arm assembly to 119 ft. lbs. (161 Nm).
  5. Fully tighten the No. 1 rear suspension arm assembly to 70 ft. lbs. (95 Nm).
  6. Fully tighten the No. 2 rear suspension arm assembly to 119 ft. lbs. (161 Nm).
    NOTE If it is necessary to replace the hub or bearing, replace the components as an assembly.
    Rear tire and wheel assembly If equipped with rear disc brakes, the caliper mounting bolts. Leave the brake line connected and suspend the assembly out of the way. Brake rotor or drum 4 bolts and pull off the rear axle hub O-ring
To install:
    Hub on the carrier and tighten the bolts to 59 ft. lbs. (80 Nm) Rotor or drum Caliper, f equipped with rear disc brakes and tighten the bolts to 34 ft. lbs. (64 Nm) Wheel
  2. If equipped with air suspension, move the height control switch in the trunk area to the OFF position.
    Negative battery cable Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Cotter pin, lock cap and the nut holding the halfshaft to the rear axle Suspension member brace by removing the 2 bolts Halfshaft bolts and washers Halfshaft from the vehicle Strut rod
  4. Place matchmarks on the adjusting cam and body for the No. 1 control arm.
  5. Remove or disconnect the following:
    Nut and adjusting cam Nut on the axle carrier side of the No. 1 lower control arm Separate the control arm from the axle carrier No. 1 lower control arm Stabilizer bar link from the No. 2 lower control arm.
  6. Place matchmarks on the adjusting cam and body.
  7. Remove or disconnect the following:
    Nut and adjusting cam from the No. 2 lower control arm Nut and bolt holding the No. 2 lower control arm to the axle carrier No. 2 control arm from the vehicle Nut and bolt on the lower side of the strut assembly 2 upper control arm set nuts and bolts Axle carrier with the upper control arm
  8. Secure the axle carrier in a vise.
  9. Remove or disconnect the following:
    Nut holding the upper control arm to the axle carrier and remove the control arm Dust deflector. Use a suitable prytool. Oil seal
    Fig. Removing the oil seal (inner)-LS 430
  10. Remove the 2 bolts and nuts and shift the backing the plate towards the hub side (outside).
  11. Remove or disconnect the following:
    Axle hub
    Fig. Removing the axle hub from the axle carrier-LS 430
    Backing plate. Inner race (outside) from the axle hub
    Fig. Removing the inner race (outside) from the axle hub-LS 430
    Oil seal (outer) from the axle
    Fig. Removing the oil seal (outer)-LS 430
    Snapring from inside the axle housing Bearing from the axle housing
To install:
    New bearing to the axle housing Snapring to the axle carrier, using snapring pliers New outer oil seal. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (outer)-LS 430
    Backing plate to the axle housing. Do NOT install the bolts or nuts at this time. Inner race (inside) to the axle housing Axle hub to the axle housing Backing plate in position. Tighten the bolts and nuts to 43 ft. lbs. (59 Nm). New oil seal (inner) to the axle housing. Coat the oil seal lip with multipurpose grease.
    Fig. Installing the oil seal (inner)-LS 430
    New dust deflector. Be sure to align the hose for the ABS speed sensor in the dust deflector and axle carrier. Upper control arm to the axle carrier by installing the nut. Tighten the nut to 80 ft. lbs. (108 Nm). Axle carrier and upper control arm to the vehicle as an assembly 2 upper control arm set bolts and tighten the bolts to 121 ft. lbs. (164 Nm) Bolt and nut holding the strut to the axle carrier. Tighten to 101 ft. lbs. (137 Nm). Bolt and nut connecting the No. 2 lower control arm to the axle carrier. Tighten the bolt to 60 ft. lbs. (81 Nm). Nut and adjusting cam to hold the No. 2 lower control arm to the body. Align the adjusting cam marks and tighten the nut to 57 ft. lbs. (78 Nm). Stabilizer bar link to the No. 2 lower control arm and tighten the nut to 48 ft. lbs. (65 Nm) No. 1 lower control arm to the axle carrier and body. Install the nut to hold the No. 1 lower control arm to the axle carrier. Tighten the nut to 43 ft. lbs. (59 Nm). Nut and adjusting cam to hold the No. 1 lower control arm to the body. Align the matchmarks and tighten the nut to 57 ft. lbs. (78 Nm). Strut rod to the axle carrier and body. Install the bolt and nut to hold the strut rod to the body. Tighten to 57 ft. lbs. (78 Nm). Bolt and nut to hold the strut rod to the axle carrier. Tighten to 136 ft. lbs. (184 Nm) Parking brake shoes and cable Outboard joint side of the halfshaft and align the matchmarks on the side gear shaft and the halfshaft. Coat the threads with clean oil and install the hexagon bolts. Tighten bolts to 61 ft. lbs. (83 Nm). Suspension member brace with the 2 bolts. Tighten the 2 bolts to 37 ft. lbs. (50 Nm). Nut to hold the halfshaft to the rear axle. Tighten the nut to 213 ft. lbs. (289 Nm). Lock cap and cotter pin Brake disc to the axle hub with the matchmarks aligned. Install the 2 screws and tighten the screws to 48 inch lbs. (5 Nm). Brake caliper to the vehicle and install the 2 bolts. Tighten the bolts to 77 ft. lbs. (104 Nm). ABS speed sensor and wiring harness Height control sensor link with the matchmarks aligned. Tighten the nut to 48 inch lbs. (5 Nm). Rear wheel(s) Negative battery cable
  2. Lower the vehicle and turn ON the air suspension switch.
Fig. Exploded view rear carrier assembly, hub and bearing-
  2. Remove or disconnect the following:
    WARNING Be careful not to damage the boot and ABS sensor
    Rear wheel(s) Height control sensor link from the lower control arm Anti-lock Brake System (ABS) speed sensor and wiring harness Brake caliper bracket from the rear axle carrier by removing the 2 bolts. Support the caliper with a piece of wire. Brake rotor Parking brake shoes and cable Toe control link Separate upper control arm assembly Shock absorber from axle carrier Suspension arms No 1 and 2 from axle carrier Rear axle from carrier
    Wheel bearing dust deflector 4 bolts and axle & bearing hub assembly
To install:
    4 bolts and axle & bearing assembly. Tighten to 48 ft. lbs (65 Nm) Rear wheel bearing dust deflector Rear drive axle Upper control arm. Temporarily tighten No 2 and No 1 suspension arms. Tighten to 52 ft. lbs. (70 Nm) Shock absorber. Temporarily tighten Toe control link. Tighten to 37 ft. lbs. (50 Nm) Fully tighten upper control arm. Tighten to 52 ft. lbs. (70 Nm) Height control sensor Parking brake shoes and cable Speed sensor Rear disc brake caliper Fully tighten shock with new nut to 52 ft. lbs. (70 Nm) Rear tire
  2. Inspect and adjust rear wheel alignment
  3. Check ABS speed sensor signal
    Rear wheel Wheel speed sensor Axle halfshaft Brake caliper and rotor Parking brake shoes Parking brake cable No. 1 lower suspension arm bolt No. 2 lower suspension arm bolt Toe control link Upper ball joint Axle carrier from the vehicle
  3. Press the hub out of the wheel bearing, then remove the backing plate.
  4. Remove the snapring, then press the wheel bearing out of the axle carrier.
To install:
NOTE Use a new toe control link nut for assembly.
  1. Installation is the reverse of the removal procedure, while using the following torque values:
    Backing plate bolts: 43 ft. lbs. (59 Nm) No. 1 lower suspension arm bolt: 55 ft. lbs. (75 Nm) No. 2 lower suspension arm bolt: 81 ft. lbs. (110 Nm) Toe control link nut: 36 ft. lbs. (49 Nm) Upper ball joint nut: 80 ft. lbs. (108 Nm) Brake caliper support bolts: 77 ft. lbs. (104 Nm) Rear wheel lug nuts: 76 ft. lbs. (103 Nm)
Fig. Exploded view rear Axle carrier and hub assembly-ES 330
    Rear tire and wheel assembly Brake caliper support bracket Brake rotor Skid control sensor wire 4 bolts and rear hub and bearing assembly Skid control sensor
To install:
    NOTE Inspect bearing back lash and hub deviation
    Skid control sensor Rear axle hub and bearing assembly with 4 bolts. Tighten to 59 ft. lbs. (80 Nm) Skid control sensor wire
    Rear disc Rear disc brake caliper assembly. Tighten to 46 ft. lbs (62 Nm) Flexible brake hose Rear tire and wheel
  2. inspect and adjust rear wheel alignment
Stabilizer Bar
  1. Remove the rear wheels.
  2. Remove the 2 nuts and left stabilizer bar link. If the ball joint turns together with the nut, use a hexagon wrench (5 mm) to hold the stud. Repeat for the right side.
  3. Remove the 8 bolts, 2 No. 1 brackets and 2 bushings. Two types of bolts are used, so make sure the correct bolts are installed.
  4. Remove the stabilizer bar.
To install:
  1. Install the stabilizer bar.
  2. Install the bushing and bracket with the 2 bolts and tighten to 14 ft. lbs. (19 Nm). Install the bushing to the inner side of the bushing stopper on the stabilizer bar.
  3. Connect the stabilizer bar links and tighten the nuts to 29 ft. lbs. (39 Nm). Repeat for the right side.
  4. Install the rear wheels.
  5. Inspect and adjust rear wheel alignment.
Strut & Coil Spring
    CAUTION Do NOT remove the center nut to the strut at this time. The spring on the strut is under high pressure and can cause serious injury.
    No. 2 luggage compartment trim cover Left and right deck side trim box Rear luggage compartment trim cover Front luggage compartment trim cover Left and right side luggage compartment trim covers Rear wheel Rear wheel fender liner No. 2 differential support protector Rear suspension member brace Rear No. 2 lower control arm Mounting bolts and strut assembly
  3. Secure the strut in a vise.
  4. Compress the coil spring
    Upper strut retaining nut Suspension support Upper insulator Bumper Coil spring Insulator
Dec 26, 2011 | 1999 Lexus ES 300
How to get the half shaft out
Halfshaft -sorry but the diagrams didn't paste into the fixya.com window, just the text. Also, this was for a 3.2L engine.
REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
    • Negative battery cable
    • Front wheel
    • Radiator skid plate
    • Transfer case skid plate
    • Brake calipers and mounting bracket
    • Brake rotor
    • Wheel speed sensor
    • Steering knuckle
  3. Support the axle housing with a jack. Unbolt the axle mounting bracket and
    remove the halfshaft/bracket assembly.
    To install:
  4. Install or connect the following:
    • Axle/bracket assembly. Tighten the bracket flange bolts to 85 ft. lbs. (116
      Nm) and the bracket mounting bolts to 112 ft. lbs. (152 Nm).
    • Steering knuckle
    • Brake rotor
    • Brake caliper and mounting bracket. Tighten the bracket bolts to 115 ft.
      lbs. (155 Nm).
    • Transfer case skid plate. Tighten the bolts to 27 ft. lbs. (37 Nm).
    • Radiator skid plate. Tighten the bolts to 58 ft. lbs. (78 Nm).
    • Front wheel
  5. Check the wheel alignment and adjust as necessary.
    Fig. 1: Exploded view of the left halfshaft, axle shaft and
    axle disconnect
    Fig. 2: Exploded view of the right halfshaft and mounting
    bracket
Oct 31, 2010 | 2002 Isuzu Rodeo Sport
How technical is it to replace a front wheel bearing on a 2005 Pontiac SV6 and can I do it without any specialized tools
you will need a big socket (20 or 21 mm) and 1/2 inch drive to remove axle nut and torque wrench to reinstall. The book DOES call for a special tool to get the hub off the axle, but I have never used one before.
  1. Raise and support the vehicle.
  2. Remove the wheel.
  3. Remove the wheel drive shaft nut.
  4. Remove the brake caliper and wire aside.
  5. Remove the brake rotor.
  6. Disconnect the electrical connector from the wheel speed sensor.
  7. Remove the wheel speed sensor connector from the bracket by depressing the locking tabs.
  8. Remove the 3 hub and bearing assembly bolts.
  9. Install Wheel Hub Removal tool J-42129 to the hub and bearing assembly in order to remove the hub and bearing assembly from the wheel drive shaft.
  10. Remove the hub and bearing assembly from the steering knuckle.
To install:
  1. Install the hub and bearing assembly to the steering knuckle.
  2. Install the 3 hub and bearing assembly bolts and tighten to 85 ft. lbs. (115 Nm).
  3. Install the wheel speed sensor connector into the bracket until the locking tabs click into place.
  4. Connect the electrical connector to the wheel speed sensor.
  5. Install the axle nut to the wheel drive shaft and hand tighten.
  6. Install the brake rotor.
  7. Use a screw driver or similar tool to stop the rotation of the brake rotor.
  8. Tighten the wheel drive shaft nut to 159 ft. lbs. (215 Nm).
  9. Install the brake caliper.
  10. Install the tire and wheel.
Sep 24, 2010 | Pontiac Montana SV6 Cars & Trucks
95 isuzu rodeo anti lock brake lite staying on and brake paddle moving up and down
You probably have a bad wheel speed sensor, Most likely the sensor is telling your antilock system to activate, causing your brake pedal to pulse under your foot, you may have to take it and get it diagnosed. or check the wiring harness's, make sure they are properly connected, behind the front brake caliper if your vehicle is equiped with 4 wheel antilock, and the rear antilock may be either behind your brake drum or caliper, depending on disc or drum brakes on the rear. Some Vehichles have a single speed sensor located usually near the center of your rear axle,instead of individual sensors on the rear. look for a wiring harness connecting to the rear axle. It will likely be the only wiring connected into your rear axle. Hope this helps
Feb 14, 2010 | 1995 Isuzu Rodeo
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Front axel
Remove the wheel and the brake caliper. Remove the two 18mm bolts that hold the brake caliper bracket, and remove it and the rotor. Remove the small bolt that holds the antilock brake sensor and remove the sensor. Remove the 32mm axle nut. The nut may be hard to remove but it is right hand thread. You can remove the two 18mm bolts from the bottom of the strut and swing the whole wheel bearing assembly out just barely far enough to remove the axle without removing the lower ball joint. The axle is splined in the wheel bearing assembly and you can knock it out with a block of hard wood and a hammer. Reach back along the axle with a long extension and remove the two nuts holding the axle carrier bearing. Be careful not to let the axle fall down and damage the axle seal in the transmission. The axle should slide easily out of the transmission and only a tiny bit of fluid will leak out. Hope this helps. Good luck.
Jun 23, 2008 | 2000 Isuzu Rodeo
Toys Logo
151 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
