Question about Car Audio & Video
Pyle phbt35 Code to enter when pairing
When using blue tooth and paring the keyboard to the tablet it ask to enter the 8 digit code on the screen and press enter on the key board.
There should be a confirmation code to whatever device you're pairing it too.
for example, if I was pairing mine to "laptop", I would see this http://cdn.makeuseof.com/wp-content/uploads/2012/09/bluetooth-pairing-passkey-on-android.png?20efae
and then type that code in.
Jun 20, 2015 | Tablets & eReaders
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
Could someone please help me with the 3-digit remote control code for my Pyle Pro P1001AT amplifier?
Since the code is generated by the REMOTE, it would help to know the BRAND of remote you plan to use. The code is not generated by your pyle amp
Mar 11, 2013 | PYLE Audio PYLE P1001AT 4-Channel 1000...
I need remote code for pyle ptc22lc
Remotes.com has a replacement remote for your Pyle here: https://www.remotes.com/SearchResults.asp?Search=ptc22lc
Dec 07, 2011 | Car Audio & Video
Em227 wont pair with samsung intensity... phone will recognize but continually get failed pairing message... please help!
make sure that the code you enter in to the phone as the pairing code is correct. most of them are 0000 or 00000, some of the samsungs are 1234.
this code must be entered in correctly to pair the device. If you are using an iphone, there are some issues with it people report.
Aug 24, 2011 | Southern Telecom Emerson Bluetooth Headset...
Need connection code to enter in to phone after pairing
connection code for pairing devices can be at your own choice...If you enter 1 as passcode,you should enter 1 also to the device you wish to pair like computer or other mobile device.
Jul 23, 2011 | Cell Phones
I dont know where to find pairing code
If you are connecting to Bluetooth headset, check the manual of Headset to find default pairing code.
If you are connecting to other mobile phone or laptop, you have to enter any pairing code you want and then enter the same pairing code to other mobile or laptop and both devices will be paired.
May 25, 2011 | Cell Phones
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 | Cell Phones
I DONT KNOW THE PAIRING CODE FOR LG GM200,SO I CANT PAIR IT WITH MY LAPTOP TO SEND DATA
you'll need to enter the pairing code yourself, enter like 1234 if it asks from either and enter the same on the other (1234) that will pair the two.
Hope this helps,
please rate if it does
levibit
Dec 18, 2010 | LG GM200 Cell Phone
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
