Question about Schwinn 220 Recumbent Bike
States Please Stride - Schwinn 220 Recumbent Bike
My daily steps are not registering as much as when surge was new in February. My daily log would be roughly around 11000 steps per day with out workout. My job has not changed and now Fitbit is showing...
To adjust your stride length on your Dashboard, please do the following:
  1. Log into your Fitbit.com Dashboard.
  2. Click on the gear icon in the upper right corner of your Dashboard and select "Settings."
  3. You will see a field for Stride Length and Running Stride Length. ...
  4. Click the "Update Profile" button to save your changes.
A lot of information on setup is available on your windows app or at this link:
Fitbit Official Site for Activity Trackers More
Oct 11, 2017 | Cars & Trucks
How many miles does 6710 steps with a long stride
5,280 feet in a mile. Assume 3 feet for a long stride, multiply 3 x 6710 = 20130 feet. Divided by 5280 = 3.8125 miles. Adjust math for stride length if different.
Feb 10, 2015 | Cars & Trucks
How many miles are in 5101 steps
That depends on the length of your stride. If you have a very short stride (less than 12 inches), it'll be less than one mile. If you have a very long stride (36 inches or more), it'll be more than three miles.
Jul 29, 2014 | Exercise & Fitness
How does a person convert the steps to miles? How many in a mile?
Thats pretty hard to do since each persons stride is different. If you know your stride length then you can just multiply the length of your stride by the number of strides. S x N.
Oct 18, 2013 | Exercise & Fitness
Can't input stride length
My husband figured it out! Follow the instructions for setting time and _user information_, toggle the "set" button until you get to stride length (I think it's factory default setting is 33 inches). All the parameters listed at the end of this section are set this way.
May 20, 2012 | New Balance Balance Via Active Pedometer
Need stroller manual
Either call Kool Stop in Oregon and ask for the Kool Stride manual you need or download this online one which is similar...
http://ebookbrowse.com/kool-stop-kool-stride-sr-paramount-series-jogging-stroller-owners-manual-pdf-d359030674
Apr 10, 2012 | Baby Gear
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
I need an illustration of hook up to bike for my ride n stride in step
You can get the manual on the link below. If it is the wrong manual can I get the model # so I can get you the right one.
http://www.instep.net/productInstepPDFFiles/109pdf-1.pdf
Good Luck and please rate 4 thumbs up for the free answer
Sep 25, 2010 | InSTEP Ride N' Stride MK750 Twin Seat...
How do i set the stride for the sportline 2007 model 4202
5. Press MODE button to reach the MILE MODE.
6. In MILE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these
8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to MILE MODE.
Sep 20, 2010 | Accufitness SportLine Electronic Pedometer...
Schwinn 220 Recumbent Bike Logo
16 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
