Question about Hitachi 42PD6600 42 in. HD-Ready Plasma Television
Can I set the default input?
I have my sky HD box setup to work on Input AV-6 as that is the HDMI port but if the TV is turned on and off it always defaults back to AV-1. Is there a way to tell it that I want AV-6 to be the default?
  • 378 Answers
Some tv model has a setting that every time you switch on the tv the set will back on the last customer setting, other tv does not support this setting. But if your tv works as i mentioned earlier during the first time you buy it. Meaning the IC memory is malfuntion.
Posted on Jun 14, 2009
How to set a default source input
here's the manual should be here...
http://www.fixya.com/support/p220809-philips_42pf9966_42_in_hdtv_ready/manual-52991
Jan 03, 2018 | Philips 42PF9966 42 in. HD-Ready Plasma...
Sky new zealand say my hd z70rx5 is unable to recieve hdcp even though the specs say the set is HDMI AND HDCP complient,they say no rear projection is able to receive hd is this true,any help i would be...
Terminals and Connections Dual HDMI digital inputs with HDCP (High Definition Content Protection) offer an uncompressed solution to the transmission and display of high definition video and audio content. All JVC HD-ILA TVs also include dual auto sensing component video inputs, assuring the best possible picture quality whether a viewer is using DTV, D-VHS or DVD, and three S-Video (two rear, one front) inputs and four AV inputs (three rear, one front).
hdmi.gif High Definition Multimedia Interface
HDMI is a new standard digital connection between A/V devices, such as a set-top box, DVD player or A/V receiver, and a digital television. HDMI offers exceptional video and audio quality with a single quick-disconnect connector. It supports multi-channel digital audio transmissions and component video color spacing for true rendering of HD video.
We carry a full line of high-performance HDMI cables. See them here...
Audio Features The JVC BBE High Definition audio system with Advanced HyperSurround and Active Hyper Bass includes two direct-drive speakers mounted underneath the screen for rich, expansive sound that fills your home theater or TV room.
Aug 06, 2008 | JVC Televison & Video
How do I connect my Toshiba SD5010KB thru my Sky Box.
HDMI Tv's have a HDMI input and connect that the to the HDMI input on back of HD Sky box if not HD ready TV you'll have either 1 or 2 F-Connectors which go from Dish to input points1 and 2 on the back of the sky box then Scart lead from box to TV -
May 22, 2011 | Televison & Video
TV does not have aHDMI port so what audio and vdeo csbles needed to connect to a Sky HD box ?
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
Jan 16, 2011 | Philips 50PF7320A 50 in. Plasma HDTV
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
I cannot get my hd box to overwride my analog tv
The hd box does not have hdmi over ride unlike the scart output. You havent said if this is hd ready tv if so most TVs will stay on the same av/hd input.
Sep 16, 2009 | Hitachi L32H01 32 in. HD-Ready LCD TV
Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
Jul 19, 2009 | Televison & Video
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Dec 22, 2007 | LG 42LC2D 42 in. LCD HDTV
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Hitachi 42PD6600 42 in. HD-Ready Plasma Television Logo
488 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
