Question about D-Link NetDefend DFL-200 Firewall
Dfl200 Public and Private Ip
Is it possible to use firewall where it also do the natting and allow public ip for some computer on lan
thanks
nauman
  • itsnomihere Jun 16, 2009
    can you explain a bit more
    from where i can put my public ips on dfl200
    and how
  • 428 Answers
Of course . That's what NAT is all about :)
Posted on Jun 15, 2009
I need help opening my nat settings?
Is it for some gaming console??? they use the term NAT for some user control settings i think, nothing to do with NAT in a router, the term NAT for a router is (Networke Adress Translation) you can not (set it) or (un-set it) it's what makes your LAN networke comunicate with the internet, to be more technical, it is what translate a range of IP (public/internet) address to a different IP range (private/local) so traffic can go through and using rout tables)
And just in case you have a crasy idea to play with the router's firewall/DMZ... it has nothing to do with the firewall of the router either... I'm not a gamer at all, but look for the settings you need in the console it self...
Cheers!
Apr 14, 2011 | Arris SURFboard SBG900 Wireless Router...
I have a cisco RV120W small business router. I am trying to access a server on the LAN from an external public IP. I have created a firewall rule but have not been successful in getting it to work. I can...
Well, you will need to do two things, make sure your ACL's are set up right and you will need an ip route statement, such as this:
ip nat inside source static tcp 192.168.1.15 80 1.2.3.4 80 extendable
In this example, any traffic from outside coming into IP 1.2.3.4 on port 80 will be forwarded to a server on 192.168.1.15 port 80.
Feb 23, 2011 | Cisco RV120W WIRELESSN VPN FIREWALL Router
Need to allow a telnet session thru a speedstream 5660 modem/router having a public ip and allow it to connect to a private ip on the internal LAN. how do i accomplish this?
According to the user manual:
Page 16:
HTTP Web-browser Access
Most HTML browsers can be used, though Internet Explorer 4.0 or Netscape 4.0 are recommended. IE 2.0 and Netscape 2.0 and their predecessors are not supported. The HTML interface can be used to access the LAN (or WAN) IP address or it can be used with FTP to upload and download files to and from the router.
To log on to the modem via HTML:
1 Bring up your favorite web browser.
2 Enter the Ethernet IP address of the router (10.0.0.1 or Speedstream) in the "Location" or "Address" area where you enter web page addresses.
3 Refer to "HTML Web Interface" on page 20.
Page 20:
HTML Web Interface
The HTML interface for the router first displays a page showing the current configuration of the router. The first page also provides links to the following functions:
Advanced Setup
Leads to a more detailed interface with several links that allow more in-depth configuration of functions available on the router. This interface provides the following links:
Configuration Procedures
Status and Statistics
Command List
This is where the user manual ends. I would suggest clicking "Configuration Procedures" and find the section for configuring Network Address Translation (NAT).
In that section (if it exists), you'll want to provide the private IP address of the computer running the Telnet server and forward port 23 to this IP address.
If NAT capabilities do not exist, I would consider changing the router to Gateway mode (described in the user manual) and buying your own router to handle the NAT firewall.
Dec 29, 2010 | Efficient Networks SpeedStream 5660 Router
How do i forward a port i want to play call of duty black ops but i cant find an online game, the game website says to forward these ports, TCP [80] UDP [88, 3074, 22728, 33233] but i dont know how to...
http://www.netopia.com/support/hardware/technotes/NQG_025.html
Server List (Port Forwarding) NQG_025 With NAT enabled, the IP addresses of nodes on your LAN are private since they are hidden from the Internet. IP Servers let you pass specific types of network traffic through the Netopia router's NAT interfaces. Once configured, selected types of network traffic, such as FTP requests or HTTP (Web) connections, will be forwarded to a specific host or server behind the Netopia router. Please Note: From the LAN (Local Area Network), you will also be able to access the servers that are responding to requests from the internet, but only using the internal private IP address. Access via the public IP address is not supported from a local ethernet connection. If your ISP is routing you multiple public IP addresses, you can also configure the router to forward all ports in one public IP to a designated private IP address on your LAN via Easy PAT List entries. For those instructions, see Quick Guide NQG_024: IP Mapping (Address Forwarding).
Please Note: If your router is currently running Netopia Residential Firmware with a web "GUI" configuration menu, this technote is not applicable to you. Most 3300 Series Netopia Gateways can be upgraded to Enterprise level firmware. Click Here! to purchase the upgrade key.
Related documents: NQG_039 NAT and the Basic Firewall
Firmware References:
  • v8.2 R1 (and up) - 3300 Enterprise Series
  • v5.3.7 (and up) - 4000 Series
  • v4.8.2 (and up) - R-Series
Before You Start
Telnet into the Netopia router's Main Menu at 192.168.1.1 (if using the default IP setting). If your network has a different IP addressing scheme, modify this accordingly. Click Here! for instructions on using telnet and Hyperterminal (serial connection).
Login with the user name and password. The Superuser login is required to save changes. If you are unsure of this, contact your network administrator.
Don't forget to press the Enter key to save any entries. Hitting the back space, delete or tab without first hitting enter will undo any changes.
The Esc key will take you back towards the main menu screen.
Once you have completed your configuration, you should reboot the Netopia to save and apply your changes.
The Netopia Main Menu Interface
Server List Configuration
  1. From the Main Menu of router console screens, go to Quick Menus, and select Network Address Translation.
  2. Select Show/Change Server List.
  3. Select Easy-Servers.
  4. From the Show/Change NAT Server List screen, select Add Server.
  5. Select Service and the service and port you want to allow. If your service and port are not available in the pull-down menu, select Other. Selecting Other will allow you to enter a specific service port or a range of ports since fields are provided for both a First Port Number and a Last Port Number. To allow a specific service port, the First Port Number and Last Port Number should be the same. Select Okay.
  6. Next, enter the Server Private IP Address, or the private IP address of the host/server you are forwarding the service to, and the Public IP Address you want to associate with the same host/server. This value can be left set to 0.0.0.0 if you are using the WAN IP as the Public IP address. Note: If your ISP is routing you multiple static IP addresses, other then the one used for Internet access, you may create more than one server for specific service as long as all servers have a different Public IP Address specified. For example, with two web servers on your LAN you would need to create two Server List entries for TCP 80 (www-http). Since each specific port (service) can only be mapped once using any given Public IP Address, a distinct public address must be used for each TCP 80 server list entry. It is not necessary for you to specify more than one Local WAN IP Address or Public IP Address in your router's configuration. As long as you are connecting to your ISP via a public IP address used for NAT, they are responsible for routing all other IP addresses via that connection.
Conclusion
You have now configured your router for TCP/UDP port forwarding. If you have a switched connection (ISDN or Analog), you will need to either disconnect and reconnect your Internet connection, or restart your router for the Nat Server List changes to take effect. If you wish to filter traffic for your static IP mappings, please see the following Netopia Technote:
NQG_039: NAT and the Basic Firewall
Nov 12, 2010 | Netopia CAYMAN 3387W-ENT CABLE/DSL...
Nokia IP 260, allowing a remote office having a direct connection
You should disable NAT between your local networks in the Checkpoint NAT policy (Create a NAT rule above all and put all your networks in the source and destination - as a group)the leave Original in the translation column.
Jan 12, 2009 | Nokia IP 260 (2 Pack) (NBC0260000)...
N.A.T Settings
So you want the public IP address that your Netopia router is getting to do a 1 to 1 NAT to the private IP address 192.168.1.136? Basically you want to bypass any of the firewall restrictions of the router?
The caveat with this configuration is that if you don't have any other public IP addresses for the actual Netopia router to use then all other devices on your network will now longer be able to access the internet through the router. Only if you have a public IP address that you can assign the router will it be able provide NAT and internet access to the rest of your network.
The 192.168.1.0 network is not routable on the public network. You need your entire network to NAT through your router using a public IP address.
You configuration will work if the Netopia router will allow a 1 to 1 NAT to another node on the network and allow NAT'ing for the rest of your private network concurrently. Of course you need at least (2) public IP addresses in the same subnet as well.
Hope this helps. Let me know if you need better clarification.
MO
May 24, 2008 | Netopia ADSL 2+ MODEM 10/100 EN AND USB...
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
All Public IPs
In order to use your DFL-200 as a firewall, and not a router, you will need to put it into "transparent mode." This will allow you to use only public IP addresses and you will not be using NAT.
Jun 20, 2007 | D-Link NetDefend DFL-200 Firewall
Open Questions:
D-Link NetDefend DFL-200 Firewall Logo
238 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
