Question about ACT Nissan 2002-2005 Altima 3.5L, V6 Heavy Duty Clutch Kit NA3-HDSS
Check engine light error code P0024 - ACT Nissan 2002-2005 Altima 3.5L, V6 Heavy Duty Clutch Kit NA3-HDSS
What are the probable causes of camshaft sensor DTC?
Camshaft sensors do go bad. They can go bad slowly, so you don't notice the badness until your engine stalls, but restarts, or you get a "check engine" light. They are not expensive or hard to replace.
Nov 10, 2015 | 1999 Isuzu Rodeo
Error code troubleshooting
It's your AVCS/cam shaft issue, bring the dealership since this issue is on Subaru TSB. Possible they replace the ECU/ECM unit.
02-132-12R Technical Service Bulletin Diagnosis and Repair for AVCS-Related DTCs P000A, P000B, P000C, P000D, P0011, P0014, P0021 and P0024
Jul 21, 2014 | 2012 Subaru Impreza 2.0i 4dr Hatchback...
I get a fault code 24 what is it telling me is wrong with my car and what does 24 mean in fault codes
That code is for the air intake temp sensor. It has failed, is dirty or loose.
Jun 03, 2014 | 1992 Toyota Paseo
Check engine light on with the TPS code. replaced TPS and pig tail and it checked out OK with volt meter. The light still comes back on with the TPS code
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
CHECK ENGINE LIGHT
http://alltypesofpartsreplacing.blogspot.com/2012/12/check-engine-lightengine-warning-light.html
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
These will help.
Thanks.
Dec 06, 2012 | 1999 Chevrolet Astro
My 01 gmc jimmy spits and sputters on take off and rpms jump around
As per your problem,the check engine light comes on due to technical problems in your car.In this case i suggest you to click the link below :----Check Engine Light On car? http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
------------Basically the computer needs to be scanned to retrieve the error codes stored in ECM.In this issue,i suggest you to click this link:----How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html----------After scan procedure you will get P4 digit error codes.If suppose you get this error codes,then click the link below,to know more about error codes:----
Check engine light with codes P2195 and P2197?http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------------There are many other reasons to for check engine light coming ON,i suggest you to click this link below and go through its troubleshooting procedure:---------Car jerks while going uphill and Check engine light is ON?http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
--------One more reason is as follows :----After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
After replacing throttle body the Check engine light starts blinking?http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
This will help.Thanks.
Feb 16, 2012 | Cars & Trucks
How to reset engine service light 2001 lincoln towncar
Check engine light with codes P2195 and P2197? http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
---------------There are many other reasons to for check engine light coming ON,i suggest you to click this link below and go through its troubleshooting procedure:---------Car jerks while going uphill and Check engine light is ON? http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
After replacing throttle body the Check engine light starts blinking? http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
This details will help you.Thanks.
Feb 16, 2012 | Lincoln Town Car Cars & Trucks
Ml350 replaced a/b cam position sensor reset computer & and erra codes p0016/p0016 check engine ligth is reset car drives with light off when engine is turn off and started the light goes out if you...
P0010....'A' Camshaft Position Actuator Circuit (Bank 1)
P0011....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012....'A' Camshaft Position - Timing Over-Retarded (Bank 1)
P0013....'B' Camshaft Position - Actuator Circuit (Bank 1)
P0014....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015....'B' Camshaft Position -Timing Over-Retarded (Bank 1)
P0020....'A' Camshaft Position Actuator Circuit (Bank 2)
P0021....'A' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022....'A' Camshaft Position - Timing Over-Retarded (Bank 2)
P0023....'B' Camshaft Position - Actuator Circuit (Bank 2)
P0024....'B' Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025....'B' Camshaft Position - Timing Over-Retarded (Bank 2)
I think your sensors are pattern parts and the readings /resistances are not the same as the original parts ,try some bosch units is my first suggestion ,
Nov 02, 2010 | Mercedes-Benz ML350 Cars & Trucks
How to reset the check engine light on Kymco 500
You will need a Engine error code reader and will need to read error codes listed and erase all error codes which will reset the bike check engine light.
Jun 21, 2010 | 2005 Kymco Xciting 500
Check engine light is on
The check engine light comes ON,when there is error code stored in the car computer. to get car scanned at diagnosis center to get error codes, At diagnosis center you will receive the error code.As per the error code it will detect the exact faulty part in the car due to which the problem is occurring.For more help :--- at www.autozone.com its absolutely free to get car scanned.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 10, 2010 | 2002 Dodge Caravan
ACT Nissan 2002-2005 Altima 3.5L, V6 Heavy Duty Clutch Kit NA3-HDSS Logo
Top ACT Computers & Internet Experts
David Payne
David Payne
Thomas Perkins
Thomas Perkins
Are you an ACT Computer and Internet Expert? Answer questions, earn points and help others
