Question about Delfield Freezer 6125XL-S
Help with charge
I the compressor on this unit and am concerned about the amount of HotShot to charge it with
  • Delfield Master
  • 1,230 Answers
I would suggest charging about 2 oz below label then charge by pressures if it is a TXV. Cap tube is critical charge so i would as the manufacturer of Hot Shot. Not recommended to use hot shot on cap tube systems. My opinion only.
Posted on Feb 11, 2017
What should the refrigerant pressures be on a reach in freezer that uses 404A refrigerant
Generally, low side is around 20-25 PSI and High side is about 235-250 when unit is close to operating temp. Expansion device effects this to some degree such as a cap tube can restrict and affect pressures as well as the amount of the charge in the system. Compressor efficiency is another.
Jan 19, 2018 | Freezers
How do I recharge a 15 yr old Freezer Model #UL2494ECW8
U have to buy and install a shrader valve on the low side going to the compressor. Correct refrigerant charge is critical and you need to carefully measure and introduce the correct amount of freon, preferably with a refrigeration scale.
Jun 02, 2015 | Freezers
Will not get cold
Hi Ebony! Are you having issues with the unit turning on at all and staying on? Or do you not hear the unit turning on and running? If you hear no noise, to show the unit is running (compressor turning on), you would need to contact a professional at your earliest convenience. The compressor and sealed system are not turning on. If you hear the compressor running, but the unit is not cooling you have a coolant/sealed system concern. Please contact Frigidaire and a professional to repair the unit.
Sep 04, 2013 | Frigidaire Freezer GLRT183TD
This unit was purchased new 61 months ago. First instance of any problems, ever, today it seems food isn't being kept frozen solid. We suspect the compressor is having a problem. There was no sound...
Yes it is a very big concern.It sounds to me like your condenser is dirty and the compressor gets hot and goes off on overload.You can tell by putting your hand NEAR the compressor.Be careful as the compressor can be very hot
Sep 14, 2010 | Frigidaire Freezers
What's the amperage on my Hotpoint Freezer? I want to calculate how much this unit is costing me in energy. Model number FV15CRB, serial number(?) AV 336553. Thanks!
Hi, to find out the total amperage of your unit, you should have a data plate most of the time, located inside with the compressor amperage, and both fan motor amps. If not inside, it will be outside of the unit. It will tell you the RLA and the FLA of each. It will also show the freon type and amount you use. Also, on top of your compressor is a plate that has the RLAmps on it also. This is what you need to find on this unit to help you on your calculations.
A/C, Heating, & Refrigeration Contractor
Jul 19, 2010 | Hotpoint Freezers
This unit has a crank case pressure regulator and it is icing up I am unsure of the correct charge becauase the data plate is gone; however I did adjust the cpr valve to where i had a svt of -20 and this...
Freezers usually have a super heat of 6-8 degrees and as it approaches the set temperature, it can be as low as 4 degrees. you will have to 'babysit' this and adjust as you go but it has to be done in extremely small amounts. the crankcase pressure regulator basically keeps the compressor from being overloaded from high pressure like from after a defrost or the door being left open.
Apr 29, 2017 | Hussmann Commercial Freezer DCCG-12
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
Need to know what type of freon to use to recharge a one yaer old Beverage Air Sandwich table refrigeration unit. Is this the same process as recharging an automotive AC system?
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Mar 29, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
no you don't want 22 its for ac they have a new product out now for sealing leaks its like stop leaks for sealed systems can find it here its called acr superseal put it in bring your low side between 8-10 and you will work fine now i had one of my inst at frigidaire put 134 in an r12 system and he said it was still going strong after 2 years so use your judgement there
Sep 11, 2008 | Freezers
Delfield Freezer 6125XL-S Logo
Top Delfield Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Freezer Expert? Answer questions, earn points and help others
