Question about Channel Master (9537) Remote Control
Harmony 650 and CM 9537 - Channel Master (9537) Remote Control
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
Tip
To remove back of Harmony 650 - 6 screws
Tip - I had a defective Harmony 650 with the backlight staying on problem. I thought I would remove the back to view the timing crystal. Just note that there are 'six screws' to be removed to get the back off. Four next to the batteries and 2 under a semi translucent piece just behind the LED cover The small piece is attached by some double-sided tape. On it is written 'Harmony Technology'. It has to be carefully pried up so as not to damage it. You will then have access to the two last screws.
on Mar 23, 2011 | Audio Players & Recorders
How do I turn off closed caption on Logitech Harmony 650?
It depends on which device your trying to talk to. If its the cable/satellite box, press the devices button on the harmony and select which device your needing to turn the closed caption on or off with. Then scroll the pages until you find the "CC" or caption button.
Nov 28, 2014 | Logitech Harmony 650 Remote Control Silver
How to reset harmony 650 for 'system error!' ?
If your remote is not behaving properly, you can reset it. To do so, remove one of the batteries, hold down the All Off button, and reinsert the battery. A message will appear on the remote screen indicating that the remote has entered safe mode. Next, connect the remote to your computer and sync it. The remote should now be updated and functioning properly.
May 12, 2014 | Logitech Harmony 650 Remote Control
Can I change the frequency from radio to infrared in order to use the Logitech Harmony 650 infrared remote control
You want to use a Logitech Harmony 650 remote to control an Emerson shelf system, so what's the problem?
Nov 25, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
Logitech harmony 650 remote doesn't work with old Roku player
I have an old Roku and was able to get the harmony 650 to recognise it. The model of my old Roku was SD since I originally used it on my analog TV. Everything seems to work without having to "teach" the Harmony. The only quirk was having to use the Exit button to go back to a Netflix movie description and again to go back to the channel list.
Jan 15, 2012 | Logitech Harmony 650 Remote Control
How do you timer record programs on logitech harmony 650
You would need to Learn the "record" and "timer" commands from your original remote - Remember, your Harmony remote can only Mimic the commands your original remote has!
Here's the user manual in case you have questions: http://images.harmonyremote.com/EasyZapper/Downloads/UserManual/Harmony650/enu/Harmony650_UserManual.pdf
As well, here's the link to learning these commands from your Original remote: http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9605
Elle
May 15, 2011 | Logitech Harmony 650 Remote Control
I have no power on my harmony 650 remote. I have changed the batteries with no result.
It is possible that the remote had fallen down or there was leak on the battery to the board within. If so the remote control printed board can get defective.
Please check this link below for some help.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Feb 02, 2011 | Logitech Harmony 650 Remote Control
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
Channel Master (9537) Remote Control Logo
48 people viewed this question
Top Channel Master Televison & Video Experts
Peter Privates
Level 1 Expert
ELECTREPAIR USA
ELECTREPAIR USA
Are you a Channel Master Televison and Video Expert? Answer questions, earn points and help others
