Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
your internet cache may be slow due to following reasons - Your browser memory cache is so full, your browser has to slow down to allow for its limited hard drive space. - You might have spyware/malware infecting your machine, and secretly using your Internet bandwidth. So You need to optimize browsers and internet connection. - First of all update the browser - Disabling The Firewall - Remove unwanted tool-bars and plug-ins - clear temp files - Deactivate background running services If you are unable to perform above tasks then use a single utility tool like PC Fresher that will not only fix windows errors but will also optimize Internet
Straight from the user guide, just discovered it today because I have also been having this frustrating problem. Use Fn + F6 - it is a toggle switch to enable and disable the Touchpad. I have a Lenovo wireless mouse now instead.
I would start by cleaning the machine with CCLEANER free found at: http://www.filehippo.com/download_ccleaner/. Now what is running on your machine that is not needed, use CCLEANER ,TOOLS, STARTUP, to disable what is not needed to start at startup. I have no idea what is running on your machine but remember everything that is open will use memory and cpu power. look at Services and task manager , processes, for memory hoggs that are not needed. Get rid of TOOLBARS on browsers they are killers. Also install and run MALWAREBYTES free :http://www.filehippo.com/download_malwarebytes_anti_malware/ Take a look at this tutorial: http://www.computingunleashed.com/speed-up-windows-7-ultimate-guide-to.html
There are so many reasons can cause a Lenovo U350 running slow than
it used to, it is hard to identify just what might be dragging down your
Lenovo's performance, let alone implement the necessary technical
adjustments to fix it. So if you want to address the issues more
easily, I'll recommend you try a Lenovo speed up software.
Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
need to consider the speed of your internet connection. the type of browser your using. and how many programs running. and how many browsers are open. check how much ram you have.
It is a fault with Lenovo laptops. My cursor jumps all the time, no matter what software I am using. It is NOT the 'sensitivity' of the touchpad, for my cursor jumps even when I am not typing, even if I don't touch the laptop! I can set the cursor to a certain point on a document and then, after about 30 seconds, it will just jump to another point, even if I am in another room.
