Question about Stanley Bostitch SB1664FN 16 Gauge Straight Finish Nailer
16 guage FN1664 leaks air
My brad nailer model FN1664 leaks air when I plug it in & won't pressure up & shoot it sounds like an internal leak in handle
    New Friend:
  • 131 Answers
Needs new trigger valve.
-Jeff
Posted on May 07, 2014
  • 4234 Answers
SOURCE: Bostich N80 Framing nailer
Sorry about the delayed response. This unit needs to have the O-rings replaced. The return of the firing pin is not happening correctly. This means that the pressure release holes are still engaged. When the pin pushes out the nail, the return should cause the holes to get covered. If there is an air leak, the return will not complete resulting in an even larger air leak which is what you are now seeing. This is a relatively simple repair for any shop that handles these and would be considered a standard maintenance effort. These are decent tools and with proper maintenance will last for years. Mine is over 22years old and going string.
Dan
Posted on Feb 11, 2009
  • 7 Answers
SOURCE: constant air leak
Sounds like you need a repair kit or take to a tool company that installs the kit.
Posted on Jun 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: Air leaking near trigger
the purple O ring is split I would take it back or if you want to try and fix yourself let me know and I will help
Posted on Oct 02, 2009
  • 6 Answers
SOURCE: Bostitch coil nailer does not cycle. Sounds like
drive pin o ring is shot. deair the gun remove top pull drive pin replace oring oil the heck out of it and go to work
Posted on Dec 01, 2009
SOURCE: We have a Bostitch nailer that leak out of the end
you need oil....put oil in the mail fitting, just a little and it will go away. your o rings are dry and wont create a seal.
Posted on Mar 09, 2010
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Sounds like air leaking inside won't pressure up & shoot
It probably needs servicing. Strip gun & clean it may have water inside from compressor and/or may have too much oil inside (may have no oil at all and be seizing up). Clean & check O rings. ( I replace O rings during a service). When rebuilding apply a little Teflon grease to the O rings and smear a little inside the sleeve, do not add oil at this time. Connect to airline and check for correct operation. If all OK add a couple of drops of oil down air intake before starting work as normal.
Mar 17, 2014 | Stanley Bostitch SB1850BN 18Gauge Brad...
Internal air leak won't pressure up
Sounds like the trigger valve is bad. If the air is leaking out of the trigger you can buy a kit and replace it. Try eReplacementParts com or your local Bostitch service store. It's really simple to change, check out this site for step by step, How To Replace The Trigger Valve On Bostich Nail Gun How To Guides DIY... OEM Replacement Parts DIY Repair
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Bostitch SB1664FN 16 Gauge Straight Finish Nailer Logo
222 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
