Question about Sunbeam 2366 MixMaster Series Hand/Stand Mixer
My mixer quit while beating no sound on
I was mixing with my stand mixer and it just stopped
K45 kitchenaid mixer quits working under load? When beating egg whites it works great but try to cream butter and the beater stops.
It will be a broken or missing pin through a gear or the planetary or something wrong with the fuse gear. It should be easy enough to find but you will need to split the gearbox cases to check.
Sep 17, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
Hi i just had my mixer spark and then the motor
Could be carbon brushes, switch it's really hard to call it,
Let us know how we can help you
Nov 25, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Hi, when I turn my kitchenaid artisan on the mixer is not registering properly and is making a whirring noise but not doing anything - sounds like a fault inside - what do you suggest? Thanks Michelle
It sounds like the worm gear has failed. It is quite common when the mixer has been used to try and mix something it cannot move in the bowl:
http://kitchenaidmixerspares.co.uk/Home/tabid/36/ProductID/104/Default.aspx
Oct 17, 2009 | KitchenAid KSM150PS Artisan Series Stand...
My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Oct 11, 2009 | KitchenAid K45SS Classic Stand Mixer
KSM90 Kitchen Gets stuck in the middle of mixing Bread Dough
Hi
If you decide to get rid of it can you sell the accessories parts?. I have one with no parts.
Thanks,
Barak
baraksch@nana.co.il
Nov 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Newish mixer just stopped while mixing...no motor smell or strange sounds...
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 09, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Sunbeam 2366 MixMaster Series Hand/Stand Mixer Logo
57 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
