Question about LG DLE0332 Gas Dryer
How to remove front panel on dlg0332w - LG DLE0332 Gas Dryer
DLG0332W LG Propane Dryer, intermittent heat problem? Heats in the morning (when cold). Any ideas?
It seems to me that there is a problem with your valve assembly . I would check the connectors to the valves there should be 2 coils in there those do funny things when thy are defective.
Oct 30, 2014 | Dryers
Tip
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE.
Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf
Also applies to:
DLE5911W
DLE2511W
DLE5932W
DLE5932S
DLE2532W
DLE0332W
DLG5911W
DLG2511W
DLG5932W
DLG5932S
DLG2532W
DLG0332W
on Apr 29, 2009 | LG DLG5932W Gas Dryer
LG dlg0332W gas lights up for 4 seconds and goes out for 5 minutes and repeats
It sounds like a plugged or restricted exhaust vent or blower wheel might not b spinning, check blower and belt:)
Nov 30, 2013 | Dryers
Hi: I have a LG DLG0332W Dryer, which is running but drying. I cleared all the lint areas still nothing. Is there anything I can do, I am pretty handy. Thank You.
on the right side there is an access panel, unplug dryer, open it up and look inside you will see two wires and in the middle is a reset button, push it in and it shall dry
Feb 27, 2011 | LG DLG5932W Gas Dryer
Dryer turns itself on and off before the cycle ends
you probably have the extended tumble setting on, refer to your owners manual to learn how to shut it off
Aug 11, 2009 | Dryers
Everything seams to work but the heat will not come on the igniter will not come on gas will not come on . HELP this is a LG DLG0332w model
The ignitor may have failed, and you will need a multimeter to test it. If you do not have a multimeter, you can replace the ignitor in the chance that it is bad
Jul 04, 2009 | LG Dryers
Lg Gas dryer Dlg0332w drum making noise
The drum on my DLG0332W was also making noise at the back of the dryer...kind of a thump thump thump as the drum rotated. My dryer is only 4 years old. I got brave, downloaded the service manual and opened up the dryer. I found that the drum's welded seam was starting to separate where the roller wheels were coming into contact with the drum at the back of the dryer. Looks like a new drum is in order.
Mar 01, 2009 | LG DLE2532W Electric Dryer
Not properly drying
If you remove the front cover hitting the reset switch is rather easy. However I did that the other day and only got 1 load done before it tripped again.
I just picked this dryer up used from a buddy the other day and am already having trouble. Also... It runs very loud. How loud is yours complared to the washer?
May 30, 2008 | LG DLE0332 Gas Dryer
LG DLE0332 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
