Question about H.D. Hudson 13854 Never Pump Bak-Pak Sprayer- 4 Gallon
When switch in on makes beeping sound hudson sprayer
How do I assemble a Hudson eliminator 30151?
Go online with make and model and search or go to manufacturer web site or find a local service centre and ask there.
Sep 21, 2014 | Chapin Home and Garden Premium Nozzle Kit...
Why does my Green thumb .5 gallon sprayer leaks when pressurized?
sounds like your your rubber seals have worn out,or one has broken fully or you have not put it back on properly
Jul 18, 2014 | Green Thumb HD Hudson 79142GT Gt 2L Hand...
Looking for hudson sprayer repair kits
you will need to contact them from here
http://www.hdhudson.com/contact-us
they will direct you to the closest reseller of their kits or they can ship one to you.
Dec 29, 2012 | H.D. Hudson 2g Yard N Garden Sprayer
Why does Pump not build pressure
probably bad seals or ring or the relief valve is stuck open
Aug 29, 2012 | H.D. Hudson Hudson Pumpless Sprayer 2...
How do i fill my hudson sprayer
On the link below page 2 will tell you how to fill your sprayer.
http://www.hdhudson.com/PDF_files/poly-sprayer-instruction-sheet.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Jun 27, 2010 | Eliminator Hudson Sprayer - 1 Gallon,...
I have the hudson eliminator sprayer and squeeze the trigger I just get one burst of spray and then a couple of drips. I do have it pumped up all the way. What is the problem?
IF your sprayer is full you should be good to go after 20 or so full stroke pumps
If it is not spraying unscrew the adjustable tip and clean out the little holes around the end
If you leave spray in the unit after using it it will get crudded up and plug up
Mar 08, 2010 | H.D. Hudson Hudson, H D Mfg Co 1 - 1/2gal...
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
From jdwillia on hudson sprayer
I poured hot water in the top and let it soak for ten minutes. Removed pressure valve and it broke free.
Jun 16, 2009 | H.D. Hudson 2g Yard N Garden Sprayer
I have a hudson classic sprayer and have no instructions.
The pumping mechanism should unscrew from the plastic bottle. Push the handle all the way down and try to unscrew the pump while holding the bottle steady.
Need help with Hudson Trombone Tree and Shrub Sprayer Model 61224
There's a parts illustration on the Hudson web site that may be helpful to put the sprayer back together correctly. Here's the link: http://www.hdhudson.com/PDF_files/10.pdf
Jun 16, 2009 | H.D. Hudson Hudson Trombone Sprayer - 140...
H.D. Hudson 13854 Never Pump Bak-Pak Sprayer- 4 Gallon Logo
99 people viewed this question
Top H.D. Hudson Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a H.D. Hudson Garden Expert? Answer questions, earn points and help others
