Question about 1A Auto Parts 2001 Chevy Silverado 1500 Pickup Truck Fuel Tank Filler Neck for Fl
Chevy 2001 silverado makes a whirling noise underneath when you let off gas mostly downhill , will stop if you press gas pedal again
The noise,sounds like something unwinding and it may be in crankcase or transmission
When I press on the gas, the dinging noise that plays when the key is in and driver door is open goes off. I lift off the gas pedal,and the noise stops. Then pressing back on gas pedal the noise starts...
disconnect batt fora few min and see id car reboots---computer may need to be unplugged and pins cleaned for bettr connection----a scan with factory equipment-laptop controled-at a private mechanic is recommended----that car is very complex and should pinpoint bad areas
Mar 26, 2015 | 2001 BMW X5 3.0i
How do I rest oil change light on a 2001 1500 silveradeo?
Place a piece of black electrical tape over it ,problem solved .you know the oil is good
Oct 10, 2014 | 2001 Chevrolet Silverado 1500
How do i reset the change engine oil soon light after changing oil on 2001 chevy 1500 silverado?
press the gas pedal on the floor and turn the key on then real fast mash the gas peal 3 times fast on the trird time hold it on the floor tell the oil light resets it self count to ten. should work just fine.
Oct 22, 2010 | 2001 Chevrolet Silverado 1500
My 2001 chevy truck gas pedal sticks and how to stop the friction when trying to accellarate on the pedal at take off only
clean the throttle body with carb cleaner and rag or small brush open the blade and clean both sides and the throttle body itself
Feb 17, 2010 | 2000 Chevrolet Silverado
2001 silverado changed rotors and break still brake pedal goes to floor and makes noise randomly 96000 miles
This will be in the rear,right?The rear are what gives you brake pedal height,so check the rear,this is the most likely cause.
Jan 26, 2010 | 2001 Chevrolet Silverado 1500
Loud Knocking when pressing on gas pedal
What you are describing sounds like you have an engine bearing failing. Do not drive it 'till you have it diagnosed and repaired (most times though it's too late when you hear it.)..... Outside chance it could be the trans flex plate but I doubt it.
Apr 22, 2009 | 1998 Chevrolet Tracker
2001 chevrolet silverado z71
This sure sounds like a U joint, check them all again.
Sep 08, 2008 | 2001 Chevrolet Silverado
1A Auto Parts 2001 Chevy Silverado 1500 Pickup Truck Fuel Tank Filler Neck for Fl Logo
66 people viewed this question
Top 1A Auto Parts Car Audio & Video Experts
xxxxxx xxx
Are you a 1A Auto Parts Car Audio and Video Expert? Answer questions, earn points and help others
