Question about Golden Technologies Buzz Around 3 Wheel Scooter
Horn too loud
I want to disable the horn sound
350Z horn not sound loud
You have 2 horns,high and low,check out the connections there and the ground,could just be loose,not normal for horns to go out at this year.Have some one blow horn and listen to both to make sure both are working,One might be bad,or connections are rusted,get sand paper and rough up to get better connection,if this don't work,guess what,as you know,horns are not cheap,replaced mine on my 85 Nissan 720 4x4.Now they are loud.
Jun 02, 2013 | Nissan Cars & Trucks
2004 ford freestar horn sounds but it is not sounding loudly Almost as if 1/2 is working
check for lose or corroded conections to the horn, if still no good than replace horn (usually located behind front bumper).
Oct 08, 2012 | Ford Freestar Cars & Trucks
Horn does not work
This is common with Harley's horns. There is a screw on the backside of the horn. Turn this screw in very small increments until the horn starts sounding again. If it never does, you need a new one. Make sure you check the ground on the horn.
Jul 27, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Horn doesn't blow loudly on 2002 Escalade
It's possible that the horn exit passage is plugged with debris, but these things are usually a sealed unit which must be replaced. There should be two horns that blow together located one on each side of the radiator--if one is dead, the sound is greatly reduced. Some horns have an adjustment screw that will optimize the sound level. Hope this helps!
May 21, 2010 | 2002 Cadillac Escalade
Location of a 2003 dodge stratus horn, also not loud enough
Horns are usually in front of the radiator and behind the grill--look for two of them, one on each side. Make sure they both sound. If only one works, there is a significant reduction in sound level. There may be road debris stuffed into the horn's throats--poke a hooked stiff wire into the throats and see if anything comes out. Most are sealed and can't be taken apart to clean--replacement is about the only recourse. (look in a wrecking yard for replacements)
Nov 06, 2009 | 2004 Dodge Stratus
A very loud alarm/horn noise coming from the car
The steering wheel horn pad/button doesn't have enough clearance. In very cold weather, the contacts touch, sounding the horn. Replace or repair the horn pad
Jun 24, 2009 | 1996 Buick Skylark
2007 dodge caliber horn sounds distorted
Replace the horn(s). Some have one, some have two.
Mar 28, 2009 | 2008 Dodge Caliber
Car makes loud noise on passenger side near head light.
sounds like the blower fan. what type of chevy is it. a full size has the fan on the passenger side firewall. should be easily accessible. just disconnect the wire and test the car. if it stops making noise , that is the problem, also turn on the fan speeds to different settings, if if changes sound , that is the problem
Aug 09, 2017 | 1986 Chevrolet Nova
A loud horn like noise from the passenger side. wont go off
its your blower motor for your heat and ac bearings faulty replace blower
Jan 05, 2009 | 1987 Chevrolet Nova
Start Problem
THE AFTERMARKET ALARM SYSTEM IS ENGAGE AND NOT ALLOWING THE VEHICLE TO START. TRY TO LOCATE A VALET OR BYPASS BUTTON FOR THE SYSTEM. THE HORN MAYBE DISABLE NOT ALLOWING THE ALARM TO TRIGGER LOUDLY
Jul 24, 2008 | 2002 Jaguar X-Type
Golden Technologies Buzz Around 3 Wheel Scooter Logo
22 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
