Question about Water Heaters
Rheem rte 18 wiring diagram
Explain the double connection at the bottom of the unit
Rheem rte 13 isn't activating or heating water.
Troubleshooting Tankless Water Heaters In MINUTES Step By Step
The above video will show in detail how to solve the problem. It sounds like you need a new flow sensor.
Mar 20, 2018 | Rheem Water Heaters
What is causing electric tankless hot water heater to be needing red button reset often?
PDF]Tankless Electric (RTE) Troubleshooting - Rheem
www.rheem.com/docs/FetchDocument.aspx?ID=87d15e35-5adf-4e9f...
Tankless Electric (RTE) Troubleshooting. Technical Competence .... For four chamber units (RTE18 & 27) go to paragraph 4T. 9. Conduct OHMS resistance ...
Rheem RTE 27 Series ' Use and Care Manual
https://www.manualowl.com/m/Rheem/RTE-27-Series/Manual/296033
Rheem RTE 27 Series ' Use and Care Manual - Page 1. Use & Care Manual Electric Tankless With Installation Instructions for the Installer Water Heaters The ...
Sep 06, 2015 | Rheem RTE 27 Tankless Electric Water...
Why do lights flicker
An electric water heater will draw a lot of electricity. Your house may not be wired well, and when the heater kicks on, your lights will dim some. If your house is over 25 years old, it's likely normal.
Nov 02, 2014 | Rheem RTE 27 Tankless Electric Water...
Lights flicker
Depending on the size of the service in the house this could be a normal condition. Most newer homes have at least a 200 amp feed from the power company. If it is older it might only have a 60 amp( usually glass or cartridge fused) or 100 amp service. Could also be a loose ground or if the unit is grounded by just a conduit connection. May need to have a ground run from the breaker panel to the water heater.
Nov 02, 2014 | Rheem RTE 27 Residential Electric Tankless...
How to wire rheem tankless water heater
Open following link to see general tankless wiring instructions, with amp rating and breaker size for various tankless units including Rheem
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Nov 24, 2011 | Rheem Tankless Hot Water Heater...
Service proceedure on Rheem 16225088 .
You posted under typical Rheem tank-type electric water heater, but don't say what service you want to perform.
Listed below are typical actions one takes with electric water heater:
1) Flush tank each 6 months to prevent sediment.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
2) Inspect and replace anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
3) Test electricity from breaker box to water heater
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Troubleshoot electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
5) Clean sediment out of water heater
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
6) Save money
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
7) Do it yourself information
http://waterheatertimer.org/Do-it-yourself-water-heater-timer.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a 2 year old paloma tankles heater i get a c4 76
Make sure the wire connecting the thermostat to the unit is 18 gauge solid copper thermostat wire
Aug 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I am getting error code C7 76 on model RTGG 53DVN
is a connection between your controller and the unit disconnect the controller and see if it runs if not then it could be the PCB board. check your wires for bad connections on the remote as well
Jun 27, 2009 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
182 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
