Question about Microsoft Internet Explorer 8
Ie8 failed to install with xp sp3
Whenever i tried to install ie8 on my computer having os xp pro sp3 the attempt was futile with an error that a required update can not be installed and asking it to be downloaded manually. After downloading this update, KB932823, it was not installed since a newer version of this file is already installed
    President:
  • 3,278 Answers
Try reinstalling SP3. But, you may need to disable your anti-virus software, first.
Posted on Jun 14, 2009
  • NinaE Jul 02, 2009
    Was this helpful ??? Resolve your problem ?? If not, then back out IE8 and install IE7. There have been some problems with IE8.
    Thanks.
Getting homepage
Go to you local newspaper website to make sure you can still see it! Once there make it your default home page under IE8 option tab.
Apr 22, 2014 | Dell Computers & Internet
Lagging videos on chrome but not on ie8 all of the sudden
Computer issues like this are caused by lack of operating space.
Jul 06, 2017 | Fujitsu AMILO PC Laptops
Skype kernel32
Skype v6.6.0.106 is the last version which supports XP SP2. If you try install newer version, you will need SP3 installed, or you will get the kernel32 problem "Failed to get proc adress for getLogicalProcessorInformation (KERNEL32.Dll)".
If you don't want to install SP3 for your XP, here is a work around for you to run Skype with XP SP2.
1. Download Skypesetupfull.exe v6.3.30.105;
2. Uninstall your current version of Skype from Control Panel;
3. Block the website download.skype.com in your router or in the
Host file;
4. Delete any auto downloaded skypesetup.msi in %Temp%
folder;
5. Install Skype v6.3.30.105.
Done.
Aug 04, 2013 | Microsoft Windows XP Professional SP2
I've bought new HP DVD Writer 1135 i , which i have added alongwith my old LG DVDwriter (via SATA). BIOS is detecting both of them, where my system's OS, WinXP (updated with latest fixes) isn't detecting...
no PC stated, now that is hard.
its a IDE old DT PATA drive, its not new
could be NOS< new old stock was it sealed in a bag, air tight
no, then its not new, not NOS.
why use XP,. its dead OS. there are nobody making drivers for XP now, its dead now for 3 long years.
My guess is MS shut down the PnP engine (in there could)
3 years ago, so only your PC can make this drive work.
(your SP3, and your CAB files in said old PC)
XP 101
MUST HAVE SERVICE PACK 3 LOADED,
YOU MUST BE INTERNET CONNECTED TO GET DRIVERS
TO WORK, USING PNP , TECHNOLOGY. (if MS supports XP updates, and they say no)
best i can tell, it's a Desktop PATA IDE drive.
needs a pata ribbon and DC power jack to work
its old not new, may be new to your but it is far far from new.
does the try eject button work "? be first check.
in device, manager, you see it , right
then right click the DM line for 1135i and pick update driver.
and are connected to the internet, right:
and fails, now, means you XP is not SP3 updated
or means there is no XP driver for it.
The 2nd problem is your old HP XP computers is no longer supported at HP.com, so the DVD drivers there are long gone.
after 10 years, they go BYEBYE there.
leaving what?
XP is near useless lacking SP3,
got SP3? it also makes USB work (1/2 way)
best is upgrade to W7
or load linux. XP is DEAD !
Apr 19, 2017 | HP Computers & Internet
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
Won't install without error message
Excerpt from: http://blogs.msdn.com/ie/archive/2009/01/26/upgrading-to-internet-explorer-8-release-candidate-1.aspx
There is 1 update required when running IE8 RC1 on multi-core XPSP2 x86 computers:
KB932823 or KB946501.
This update resolves a problem in which an access violation occurs when an application exists on a Windows XP SP2-based multi-core computer. It will be installed automatically if you select “Install the latest updates” option in Setup Wizard. If this update fails to install successfully, IE8 installation will be blocked until you manually install this update from Microsoft Download Center.
So see if you can do a manual install of this update. There are a number of other suggestions in the above link that might also help.
Good Luck!
May 22, 2009 | Microsoft Internet Explorer 8
Xp pro sp3 setup problem for optional windows components
It looks like you have a copy of Zone Alarm on your PC and Windows XP Pro SP3 is not liking it. One thing that you can try is to disable Zone Alarm by right clicking on the icon that it creates on the lower right hand corner of the screen and see if you can find a "disable" or "shutdown" option. After doing so, then try to install again. Another thing that you can try is to completely remove Zone Alarm, try to install SP3 again, and if it installs, re-install Zone Alarm. However, I think the easiest path is to disable Zone Alarm temporarily. Let me know if this helps you or not.
-Serge
Mar 30, 2009 | Microsoft Windows XP Professional SP3 Full...
The application failed to initialize properly
I have the same model and problem if installing from original CD on Windows XP (the driver is old and not for XP). The new XP driver will work.
Mar 25, 2009 | Genius ColorPage Vivid Pro Flatbed Scanner
IE 8 Installation Problems
I had the same problem. I had IE7 and installed IE8. IE8 caused a lot of problems, so I used system restore. I was back to IE7 but it was not functioning properly. I had to downgrade to IE6 and then reinstall IE7. Its all back to normal. What a pain
Oct 02, 2008 | Microsoft Internet Explorer 8
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
350 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
