Question about Dometic Refrigerators
Door spring dometic oven - Dometic Refrigerators
3 Suggested Answers
SOURCE: Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Posted on Nov 01, 2009
SD Tech
  • 14553 Answers
SOURCE: dometic door on convection microwave wont stay closed
Damaged or bent latch/s---unit would have to be taken apart to see if fixable or needs parts replaced.
I would Google the full model number with "parts" to see what is available for this unit.
Posted on Jun 16, 2012
Why won't Microwave door stay shut?
We are having the same problem. Seems like latch spring is broken. We can not find any parts for this. Dometic is 3 yrs. old so no warranty. No service for it either. Keystone really took us on this
Jul 06, 2014 | Dometic DOTRC17B RV Microwave/Convection...
Dometic door on convection microwave wont stay closed
Jun 15, 2012 | Microwave Ovens
I have taken the door off the oven but how do I get the hinge into the oven section with spring loaded so tight?
When you say the spring is loaded tight I assume that you mean that the bracket is hard against the oven door. The brackets/arms have to point away from the door so they click into the oven. Normally when you pull the bracket down and away from the door you put tension on the spring. Once the bracket travels more that 180 degrees, probably to about 200 degrees the bracket won't normally spring back and should stay there by itself.
Feb 13, 2011 | Ovens
How to remove door on stoves EL716 toop oven
I can only say for the 720. You have to remove the whole oven from the kitchen furniture and then unscrew/remove the top and side panels. You will then see the springs on either side of the door.
Important. Remove the inner glass panel from the door first, before you release the springs.
To remove the springs, ensure the door is closed and then unhook them. You then should be able to remove the door frame.
May 07, 2010 | Stoves 720EF Electric Double Oven
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Mar 14, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Apr 22, 2009 | Dometic RM2452 Refrigerator
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Refrigerators Logo
10 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
