Question about Raynor Eurotech Eurotech 4x4 XL Task Chair FM4080
Repace the cylinder on a FM4080 chair.
I need to replace the cylinder for the FM4080 office task chair. Can you give me any assistance?
The height-adjustable seat back of my chair tends to fall down, as if it is too loose. Is there an adjustment to tighten this?
The "softness" is similar to shock absorbers in your car. They get tired with time. Most likely you will need to replace those parts. Or a lightly used replacement may be more cost effective.
May 06, 2015 | Tempur-Pedic TP8000 Ergonomic Mesh...
How do I lower the back of my chair
To lower the back, lift it until it stops firmly. Now let it fall all the way down. (It might need a little push to go all the way down.) To raise the back, lift it slowly until it clicks once. Each click is a height setting; it will stay at that height. Repeat until the back is high enough. To go back down, start over.
(This definitely applies to Tempur-Pedic TP4100 Office chair.)
Sep 09, 2014 | Tempur-Pedic TP4000 Ergonomic Fabric...
How to release a telescoping office chair
The information on this web page may be helpful. If the height adjustment lever is working fine then best to replace the gas lift cylinder. Help My Office Chair Keeps Sinking
Aug 19, 2014 | Furniture
Need new gas cylender
Go to http://www.trueinnovations.com They are the manufacturer of the chair. I got a replacement cylinder for $25 including shipping. Or go to amazon. The gas cylinders are pretty standard size.
Jan 24, 2014 | Serta Furniture
Office chair lowers on its own
It will be one of two things, either the gas strut is no good and in this case you might as well get a new chair. Or the lower lever is stuck in the " lower" position, if this is the case freeing it up should cure your problem
Aug 28, 2013 | Furniture
What are the different types of leather office chairs?
Here are some of the most recommended recliners that would allow you to have a comfortable seat in office.
These reclining chairs are made up of best quality materials and are available at the cheapest price on Rise and recline chairs.
Some of the best available recliners available here are:
a. MARYLEBONE RECLINER CHAIRS
b. GROSVENOR RECLINER CHAIR
c. BLOOMSBURY RECLINER CHAIR
d. SAVOY RECLINER CHAIR
e. CLARIDGE RECLINER CHAIR
f. GRAFTON RECLINER CHAIR, etc.
Jul 30, 2012 | Furniture
How do you know which office chair is the best?
While comfort is the obvious answer, there are a few otherfactors that go in to choosing an office chair since you will spend so muchtime in it. You want to consider howmuch weight it can without, if it has good customer reviews, if it swivels, ifyou can raise the seat and back, if it rolls or is stationary.
May 29, 2012 | Furniture
Raynor Eurotech Eurotech 4x4 XL Task Chair FM4080 Logo
56 people viewed this question
Top Raynor Eurotech Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Raynor Eurotech Furniture Expert? Answer questions, earn points and help others
