Question about Denon AVR-1513
The word "debug" appears on my tv screen and I can't get it off
The word "debug" popped up on my tv screen yesterday. How do I get it off there?
The display does not show, so i can't program the unit.
  1. Go to Settings on your mobile device Menu.
    Select Developer Options.
    To the right at the top of the screen is an On/Off virtual switch. Move the slider to On. There will be a check-mark pop up if it is turned on.
To turn on the USB Debugging on a Samsung 4.2.2 or higher
  1. 1
  2. 2
    Click More Menu.
    It is located in the upper right area of your screen.
  3. 3
    Click on About Phone
  4. 4
    Now, at the Android Build Number on your Samsung mobile device tap seven times.
    This will activate the Developer Mode.
  5. 5
    At Developer Mode select Developer Options.
  6. 6
    Tap the USB Debugging.
    It will turn on, and a check-mark should pop up to the right of USB Debugging.
Mar 25, 2016 | Breadman Kitchen Appliances - Others
Debug apears on left side always
Firmware corrupted. Do a firmware update. Contact any experienced service technician, of the authorized service centre to Insignia. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
The word "Debug is on my tv screen. How do I remove it?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.in job done..
Mar 23, 2014 | Televison & Video
My projection tv says "debug" on the screen what do I do?
Are you sure the message is coming from the TV or could it be comming from a component you have connected to the TV?
Mar 15, 2014 | Mitsubishi WD Televison & Video
Word "debug" on my vizio tv screen
Sounds like firmware corrupted. A firmware update might be necessary. Contract the authorized service center for Vizio.
Gopakumar Gopalan Google
Mar 10, 2014 | Televison & Video
Word Debug showing on Screen
We regret to inform you Panasonic TV's do not use any errors similar to Debug. We recommend you contact the source provider that the TV is connected to.
Mar 03, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
One day I turned on my tv and white line appeared down the middle and won't go away
If your tv is under warranty, just send it to them for fix, otherwise you need to get into the "debug" or "maintanence" menu of the tv. Google the model number of the tv and things like "debug menu", "hidden menu" or "change horizontal scanning".
Your horizontal scanning option is set too far to the right of left.
Oct 07, 2012 | Televison & Video
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Mar 27, 2009 | Microsoft Windows 2000 for PC
54" Sony Wega made a loud popping sound and now has Black lines
When I got my new LCD big screen, it had a black line across the entire width. It looked like the screen was pinched.
They claim that it can be repaired but that repair costs as much as a new tv.
My tv was replaced. Hopefully your warranty is still in place to get the unit replaced.
Mar 26, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Denon AVR-1513 Logo
19 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
