Question about Ectaco Office Equipment & Supplies
Blank vertical lines screen - Ectaco Office Equipment & Supplies
3 Suggested Answers
SOURCE: Blank vertical lines are appearing on the screen.
Hi, and sorry for my english !
Maybe the LCD driver voltage is wrong or noisy. I had the same problem: some vertical lines (not constant), pulsing contrast after powerup, pixel crosstalk, sometimes no screen
Solution: Try to replace the LCD power negative voltage buffer capacitor.
In my hardware version it is in the middle of the two T6B07 column driver IC (U3&U4) on the right side. Colored black, electrolytic type and the Value is : 10uF/25V. Chage it to around the same type.
There is enought space, so you can use a small sized non smd type capacitor. Be care of the polarity.
I hope it will help... ;)
Greetings from Hungary!
Posted on Mar 23, 2009
gopakumarg43
  • 74666 Answers
SOURCE: I have Videocon 32" LCD( VDL32HBA-FLA ) which got screen blank with vertical / horizontal lines and no osd menu
The T'Con board should be suspected. This is a common fault to most brand of LCD TVs. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Dear Sir, My Screen Of Samsung S8300 becomes blank whenever I make or call or recieve any call. In this stage the there is no response from the screen, but I can hear and talk on the phone,( I am not...
  1. first problem screen blank out
your mobile has a sensor at the top of you phone which is use to make you screen blank when you keep your phone near your ear to save power during a call.(it may be a sensor malfunction)
2.the vertical lines occurrence is common in all mobiles there's no prb with that!!!!
Jun 14, 2011 | Samsung S8300 Ultra Touch platinium-red...
My htc screen shows only thin vertical lines, how do I fix this?
it might be a faulty flex cable connector inside the housing or the LCD itself is faulty u have to replace it
Feb 11, 2009 | HTC Touch P3450 Smartphone
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
Thin Horizontal line through tv blank screen.
Replaced vertical IC ( la78041 ??>.. Or La78040 ). Look for born resistor beside IC. Replaced capacitor 100uf 35V too!!! Good luck !!
Nov 08, 2007 | Insignia NS- 27" TV27 TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
White bar on top of screen
It only 1 bar in the middle horizontal? They Call it Vertical Line, sometime looseboard, defectiveVertical IC, Leak capacitor in vertical section. need a Repairman Tech.
Nov 19, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
65 people viewed this question
Top Ectaco Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you an Ectaco Office Equipment and Supply Expert? Answer questions, earn points and help others
