Question about Stanley Air Tools & Compressors
I have a 16 guage model fn1661& it leaks air as soon as i plug it in & won't pressure up to shoot nails
I have a 16 gauge brad nailer modelFN1661 won't pressure up it leaks air as soon as you plug it in
    New Friend:
  • 131 Answers
Needs o'ring kit.
-Jeff
Posted on May 07, 2014
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 74 Answers
SOURCE: porter cable brad nailer only fires brad on second trigger pull
The dent in the wood is not caused by the air. It's caused by the set that drives the brad. Are you oiling it consistenly? Are the brads the right manufacturer for your porter cable brad nailer? From the information you give it appears that the brads are not advancing correctly or that the air pressure is not sufficient to dislodge the brad from the brad strip on the first strike - it takes an additional strike to break it free. The standard for adding oil is to add ten drops of air tool oil for every hour of operation. That seems like a lot, but the correct amount of oil is a sure way to prevent most air tool problems.
Posted on Aug 29, 2009
Testimonial: "Thanks for the info. I was not oiling it at that rate. Is there anything I can do to fix the issue now that I didn't prevent it?"
  • 8 Answers
SOURCE: my mastercraft electric brad nailer stapler wont
Look for a jam in the gun.Sounds like a brad is "hung up" in it, probably right at point where it feeds into the mouth of the firing point. Be sure you unplug it before you do this.
Posted on Jan 15, 2010
  • 100 Answers
SOURCE: how do I load nails into Bostitch SB-1664FN 16
from the side, not in the back or front.
Posted on Apr 19, 2010
  • 885 Answers
SOURCE: does the brad nailer only use 2" brads or cam
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Posted on Oct 22, 2010
Why does bn200a nailer shoot double nails
Check your compressor Pressure - it need to according to nail-gun specifications.
Usually it is mechanical pressure switch failure. Replace all with digital Controller.
Jul 14, 2014 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
I have a 18 gauge 2" brad gun when you plug the
Increase air pressure.... you're way too low......
Dec 02, 2010 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Does the brad nailer only use 2" brads or cam smaller nails be used also
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
Hello My PC 18ga brad nailer its piston wont retr...
Check the regulator gauge on your air compressor to make sure you have enough air pressure going to your nailer. After replacing my nailer because the driver wouldn't retract, I discovered, when the replacement nailer had the same problem, that I had somehow turned the regulator and decreased the pressure. Now I have two fully operational nailers.
May 20, 2010 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Brand new brad nailer shoots 2 nails and then it blows air
first make sure that you are using the right guage nails and if so I would return it to the place of purchase for replacement., the blowing of air could indicate a jammed nail in the track, look for that first and make sure the driver is retracting fully.
Dec 18, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
My black and decker 18v brad nailer will not shoot brad
look to see that you are shooting the right sized nails in it. 16 and 18 gauge nails dont interchange and the can get hung up under the plunger if the try to shoot at all
Dec 15, 2009 | Tools & Hardware - Others
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Air Tools & Compressors Logo
111 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
