Question about Golden Technologies Buzz Around 3 Wheel Scooter
Disable horn - Golden Technologies Buzz Around 3 Wheel Scooter
Why is horn stuck on?
The horn switch is stuck. If you want to disable it remove wire from horn or remove relay. You will need to replace horn button
Apr 12, 2016 | Cars & Trucks
Owners amnual 2005 toyota celica gt
The system thinks you are trying to steal the car. The first thing a theif would probably do is disable the horn. The system has disabled your ignition to keep you from stealing the car. Do you have a car remote that you can use to disable the alarm?
May 04, 2014 | 1994 Toyota Camry
How do i get my horn to stop blowing?
Find the horn icon on fuse box,. or owners manual diagram of fuses once you locate the horn fuse pull it out ! The horn will be disabled till you decide otherwise..
Feb 10, 2013 | 2001 GMC Sierra Crew Cab
How can I disable my honda accord's horn cable?
just pull the horn fuse out of the fuse panel. That would be safer, and easier. Hope this helps, James Booth
May 17, 2011 | 2000 Honda Accord
Horn going off on its own. had to disable battery to make it stop.
There's a short to ground somewhere in the horn circuit.
It's either at the horn, or at the horn switch in the steering wheel, or the wiring between, maybe at the horn relay if so equipped
Dec 14, 2010 | 2002 Mitsubishi Montero Sport
I need to disable the Horn on 1996 Jetta. Which fuse or reley disables the horn
DO NOT PULL THE FUSE you will cause more problems than you have already. Why do you want to take the fuse out?
Mar 05, 2010 | 1996 Volkswagen Jetta
My jeep horn has stopped working the fuse is fine but I dont know where the horn is to check any wires
its usually under the front bumper my horn doesn't work either in my 1999 Jeep Grand Cherokee but it bother me its just a horn and i like it disabled because when i unlock my car the flasher go off so i disabled the horn so it wouldn't beep when every-time i unlock it just the flashers go off which doesn't bother me
Nov 10, 2009 | 1999 Jeep Grand Cherokee
Disable horn upon locking doors
optional settings under driver control? deepthink
Jan 02, 2009 | 2008 Chrysler Pt Cruiser
Golden Technologies Buzz Around 3 Wheel Scooter Logo
21 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
