Question about Swingline 48209 Optima ® 45 Electric Stapler
Broken front plastic staple tray re-positioning to in-battery
The plastic retainer that is pushed to return the staple to closed position after refilling is broken.
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
How to remove starter from 2008 dyna lox rider . I have already un bolted it and removed wires but it is loose but will not come out yet .
Instructions
  1. Removal
    • 1 Remove the seat retainer screw from the seat mounting bracket using a ratchet and Allen driver. Lift the rear of the seat up and slide the seat toward the rear of the bike to disengage the seat from the frame and remove it from the bike.
    • 2 Don a face shield and rubber gloves.
    • 3 Remove the battery cover retaining screw from the bottom of the battery cover using a ratchet and Allen driver. Tilt the top of the battery cover out and lift the cover to disengage it from the battery tray.
    • 4 Remove the negative battery cable from the battery using a 10 mm wrench.
    • 5 Remove the positive battery cable from the battery using a 10 mm wrench.
    • 6 Unhook and remove the battery strap. Remove the battery from the tray. Remove face shield and rubber gloves.
    • 7 Remove the two top battery tray screws from the frame above the battery tray and the bottom battery tray screw from the inside of the battery tray using a ratchet and Allen driver.
    • 8 Remove the battery tray from the bike while guiding the battery cables through the holes in the battery tray.
    • 9 Remove the starter end-cover nut, using a ratchet and socket, and pull the end-cover off the starter.
    • 10 Pull back the protective rubber boot off the positive cable terminal. Using a wrench, remove the positive cable nut and then lift the ring terminal off the starter terminal stud. Unplug the solenoid electrical connector from the solenoid.
    • 11 Remove the two starter retaining bolts from the starter using a ratchet and Allen driver. Pull the starter off the bike. Remove and discard the starter housing O-ring.
    Installation
    • 12 Inspect the two split-ring bushings in the inner primary case where the starter mounts for slack or looseness. Remove the split-ring bushings and spread them to provide a slight interference fit in the primary housing. Push the split-ring bearings back into position.
    • 13 Install a new starter housing O-ring on the starter assembly. Install the starter assembly on the bike.
    • 14 Apply one drop of Loctite Threadlocker 243 to the treads of the starter retaining bolts. Install the starter retaining bolts and washers and tighten them to 24 to 27 foot-pounds using a foot-pound torque wrench and Allen driver.
    • 15 Install the positive cable ring terminal and nut on the starter terminal stud. Tighten the nut to 65 to 85 inch-pounds using an inch-pound torque wrench and socket. Push the protective boot securely over the positive cable terminal. Plug the solenoid electrical connector into the solenoid.
    • 16 Position the starter end-cover on the starter and install the nut, using a ratchet and socket.
    • 17 Place the battery tray in position while guiding the battery cables through the holes in the tray.
    • 18 Install the upper and lower battery tray screws and washers. Tighten the screws to 96 to 120 inch-pounds, using an inch-pound torque wrench and Allen driver.
    • 19 Guide the battery cables into the recesses at the upper corners of the battery tray.
    • 20 Don face shield and rubber gloves.
    • 21 Place the battery in the battery tray with the terminals facing out. Snap the battery strap in position.
    • 22 Install the positive battery cable and cable bolt. Tighten the bolt to 60 to 70 inch-pounds using an inch-pound torque wrench and socket.
    • 23 Install the negative battery cable and cable bolt. Tighten the bolt to 60 to 70 inch-pounds, using an inch-pound torque wrench and socket.
    • 24 Remove the face shield and rubber gloves.
    • 25 Apply a light coat of corrosion retardant grease or petroleum jelly to the terminals.
    • 26 Install the battery cover and screw. Tighten the screw securely using a ratchet and Allen driver.
    • 27 Place the seat on the bike. Lift the rear of the seat and slide it forward to engage the seat tab in the frame slot. Lower the rear of the seat and install the seat retainer screw through the seat mounting bracket. Tighten the seat retainer screw securely using a ratchet and Allen driver. Lift up on the seat to make certain that it is mounted securely on the bike.
Nov 18, 2011 | 2008 Harley Davidson FXDL Dyna Low Rider
My Bostitch MIII floor stapler is not driving staples. I partially drove one staple with a glancing blow then drove another on top. I cleared the jam and now it will not feed staples; It fires...
Slight damage to driver will prevent it from returning to top of cylinder (assuming that nailer worked correctly before double fire). Easy to check. Remove airline. Use metal or plastic to push driver to top of cylinder (should easily move). After the driver is at top, see if first cleat moved into proper positon. If cleat is not in position, check pusher and rails for debris. If cleat is in position, activate nailer to check for proper function. If driver does not return to top of cylinder and was difficult to push up, pull out driver and check for bent /damaged driver and replace orings and lower bumper while apart if parts look worn. Good luck
Jul 13, 2011 | Stanley Bostitch MIIIFN Flooring Nailers
How to repair clutch pedal safety start switch on Ford Truck F550, 1999
Clutch Pedal Position (CPP) Switch
The clutch pedal position switch (CPP) is controlled by the clutch pedal. Depressing the clutch pedal manually closes the CPP switch and allows engine cranking. The CPP switch will also deactivate the speed control system.
303-14A: Electronic Engine Controls — Gasoline Engines 1999 F-Super Duty 250-550 Workshop Manual
REMOVAL AND INSTALLATION Clutch Pedal Position (CPP) Switch Removal
  1. sxo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Always disconnect the battery ground cable prior to working on the electronic engine controls.
    Disconnect the battery ground cable; refer to Section 414-01 .
  1. Disconnect electrical connector from clutch pedal position switch (CPP) (9A837).
  1. Release the clutch pedal position switch (CPP) (11A152) from the orientation clip.
  1. Remove the plastic retainer.
    1. Push the lock tabs together.
    1. Slide the plastic retainer off the clutch pedal position switch.
  1. Remove the clutch pedal position switch.
Installation
  1. Follow the removal procedure in reverse order.
Feb 06, 2010 | 1999 Ford Super Duty F 550
Dead battery
Removal Procedure
Disconnect the negative battery cable
Remove the wheelhouse liner.
Open the positive battery cable connection cover.
Loosen the positive battery cable bolt.
Remove the front fender rear bracket to side rail bolts.
Remove the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Remove the front fender rear bracket.
Remove the battery hold down retainer bolt and retainer.
Important: Do not tip the battery more than 40 degrees during removal.
Remove the battery.
Installation Procedure
Important: Do not tip the battery more than 40 degrees during battery installation.
Install the battery.
Install the battery hold down retainer and bolt.
Install the front fender rear bracket.
Install the front fender rear bracket to side rail bolts.
Install the front fender to front fender rear bracket upper (1) and lower (2) bolts.
Install the positive battery cable (1).
Tighten the positive battery cable bolt.
Close the positive battery cable connection cover.
Install the wheelhouse liner.
Connect the negative battery cable
Oct 15, 2009 | 2006 Pontiac Solstice
Coin Tray Wont Stay Closed
The plastic spring clip had become stressed and had "moved" out of position resulting in no "retaining presure,hence the coin tray/fuse cover would not stay in the "Closed" position."Simple" $6.75 fix.
Dec 29, 2008 | 2002 Subaru Forester
How to replace spring
Hope the following is clear if not write back and I'll try to clarify, if you look at the body of the stabler molded to the body there is a bump that is round on the botton and kinda notched on top. the round part of the spring fits around the bump. The spring has a straight side and bent side. the straight side rests against the a flat bump which is slight back and lower than the round bump. the bent side clips into the notch on the handle (clip this end in last) I used a plier but there is very little tension involved the spring just returns the handle to the at rest position,
Aug 14, 2008 | Black & Decker 5700 Powershot Forward...
How do I change a staple cartridge on a Xerox 1090?
there is a grayish blue button on the finisher you have to hold down for a few seconds, the tray will drop down. There is a small door to open on the front once the tray drops.
Open the door and there will be cartridges that have orange surrounds on the cartridge. Pinch the cartridge to remove and slide in the new one, close the door and press the blue/gray button to return it to home position
Jul 09, 2008 | Xerox Office Equipment & Supplies
Swingline 48209 Optima ® 45 Electric Stapler Logo
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
