Question about Harman Kardon AVR 130 Receiver
AVR 130 CAPACITORS - Harman Kardon AVR 130 Receiver
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
What is the out put power
Hello, the avr 130 is rated at 45 watts into each of its 5 channels.
Jan 15, 2011 | Harman Kardon AVR 130 Receiver
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
My avr 130 shuts itself after appr. 1 hour . it's not overheeted. what could it be
If it's not overheating then check the setup menu for a time set for an automatic turn off.
Dec 24, 2009 | Harman Kardon AVR 130 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
How can i get my avr 130 unlocked
I just bought a new recever ,, because the avr 130 was allready old
Nov 30, 2008 | Harman Kardon Audio Players & Recorders
No speaker output
im knda in the boat. i have the avr125 and i can input but i get absolutely nothing for output
May 25, 2008 | Harman Kardon AVR 130 Receiver
Voltage Spike / Power Surge Harman Kardon AVR 130
In this case is pretty hard to give a diagnostic. There are plenty of possibilities. It has to be seen by a tech
Apr 05, 2008 | Harman Kardon AVR 130 Receiver
AVR20 II
Yes, actually there is a capacitor which is dry and needs replacement. Is located on the front panel board
Nov 22, 2007 | Harman Kardon AVR 130 Receiver
Harman Kardon AVR 130 Receiver Logo
75 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
