Question about ZTE Warp
Phone stars, android appears on screen then phone restarts.
My Lava X11 was upgrading itself yesterday night andI since then it is failing to restart, only 1st screen with "lava .....powered by endroaid is appearing for last 8 hours. What should I do?
is its battery removable or sim card pull out and refit
restart phone
if you can turn the phone off
may have to use factory reset function
Jun 22, 2016 | Cell Phones
Problems with Android OS Marshmallow. Home key does nothing, quick toggle screen won't scroll down above the notification tray, lock screen doesn't appear at any point.
If you get random errors or unstable system after an update, it's best to do a three button reset from android recovery menu. Wipe cache and delvac partitions and you should be good to go.
WARNING: this will erase all your data.
Google on how to do a reset from the android recovery for your particular model.
Mar 27, 2016 | Motorola Moto G (2nd Gen)
A star appears in the satuts area what does that mean
The Star is one of the new features (in Lollipop) and is called "interruptions" mode , which can be activated in settings. If the interrupt mode is activated as "Priority" , the star icon in the status bar of your Android smartphone appears. "Priority" in the "Interruptions Mode" means that only calls and notifications appear , which you have previously considered as important.
For the classification, navigate from the home screen of your Android smartphone:
Menu --> Settings --> Sound & Notifications --> interruptions
Now you know what the the star stands for in and how you can set settings in interruption mode. To turn interrupt mode off quickly, press once on the volume button and then select from
- None
- Priority
- All
the entry "All". Finished!
The star icon is now hidden and the interrupt mode disabled in Android lollipop.
Oct 12, 2015 | Cell Phones
How to get my android phone off of safe mode
Have you tried resetting the phone? That usually fixed the problem.
Jan 13, 2015 | Android Cell Phones
Reset phone password
Hi Oliver,
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
May 04, 2014 | Samsung Star GT-S5233 Cell Phone
Screen selecting buttons automatically without being pressed
have you tried restarting the phone or removing the battery???
Did you drop the phone?
Nov 20, 2013 | Universal STAR N8000 Android 4.0 WCDMA...
Which websitse can i download widgets for my samsung gt s5230
it's an android, right? My android's store name changed from android market or whatever to Google Play, that should come with your phone.
If you have the apps but they dont show on the app menu, theyre definitely widgets; find an oped spot on your screen and voila, one of the options will be widgets. Scroll, Select, and place them. If they dont appear on your screen after that, then you might not have provided enoough room for the widget; some are rather large.
Jul 21, 2012 | Samsung Star Gt-s5230 Unlocked Phone With...
Clear Flash Problem..
You may have to turn off factory mode again as its like a restore mode - try pressing power button for 2 minutes. Phone will restart to normal mode. Let me know if this works and if it doesnt we will try something else.....
May 07, 2017 | Star Cell Phones
ZTE Warp Logo
15 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
