Question about Mint Evolution Robotics Automatic Floor Cleaner - Model 4200
The tread came off 1 wheel and the other 1 is loose on my 4200 series mint mop how can I put tread back on the wheels
Can I glue the tread back on it's come off before and I got it back on but can't u take the wheels off to fix it
Can not catching the bobbin tread at the bottom
The bobbin may be in backwards
the needle is not the correct one for the machine
the needle isn't correctly seated in the needle clamp
the machine is a little bit out of time.
Remember to hang on to the needle thread when you're trying to pick up the bobbin thread
Turn the handwheel in the direction that would advance the fabric from the front to the back of the machine
make sure the bobbin-winding spindle has been pushed back to the left for sewing
make sure your needle is inserted correctly as far as it will go with the flat side facing back
and that the upper tension disks of your machine are threaded correctly.
Make sure the presser foot is up when seating the thread through the upper tension.
Turn the hand wheel (TOWARDS YOU ONLY) never turn the hand wheel away from you and hold the needle thread lightly. .
pull the loop up and then pull both threads (top and bobbin) under the foot and toward the back of the machine.
Also could be a timing problem
Mar 18, 2016 | SewShop.com Singer Model 347 Instruction...
The wheel on my Dirt ***** vacuum fell off. I tried putting the wheel back on but now the wheel is loose.
Hi! We recommend you take your vacuum in to a Dirt Devil authorized service center for repair. We have included a link you may follow to locate the nearest service center to your zip code. Hope this helps!
Service Center Locator
Aug 24, 2014 | Dirt Devil Featherlite Bagless Upright...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
O-Cedar Pro-Mist trigger doesn't work
This person is asking about an O'Cedar Pro Mist Mop. Not a vacuum or steam mop...
I too have problems with the pro mist handle not working... I called the customer care line at 1800-543-8105 and they are replacing my mop for free. You can also try to take it apart and fix it yourself, but I did that and I cant remember how it goes back together! lol Basically a spring comes loose from the pole inside of the mop handle, and that is why there is no tension in the trigger.
Feb 19, 2012 | Vacuums
G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
Apr 21, 2011 | Kirby G5 Bagged Upright Vacuum
I need rear replacement wheels for my Simplicity Jack Canister vacuum. They were replaced under warranty a year ago and they have cracked again. It's a plastic wheel with a rubber tread. The plastic has...
http://www.vacuums24x7.com/
They have Simplicity replacement parts. There are a number of different wheels / wheels with trays / and more. If you contact them with your make and model, they will get you the proper wheels.
Mar 06, 2011 | Vacuums
Need video or large diagram instructions for what to put together
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
ui
May 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Front wheel slips off shaft
Pull the wheel off. Look on the back side of the wheel - you will see 4 plastic pins sticking out (inside the wheel) Use a pen to push on them - this way you will remove the hub cap without damaging it. Under the hub cap you will find the screw. You will need a torx T20 or Phillips crew driver (depending on what type of screw is there) to attach the wheel to the shaft with the screw. You can use a bit of a nail polish on the screw thread to keep from coming off again. DO NOT use glue or too much of nail polish or no one will be able to get the wheel of if needed some time in the future.
If hub cap nor the screw is there - you can find it all HERE.
Good Luck,
Rocky
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
One plastic wheel on my 3102-0 broke off
Katie, I have the same problem. I have checked and you cannot buy the wheels. You can buy the whole nozzle assembly from Sears parts for $13.99. I am going to attempt to glue mine back on but I am not optimistic because the plastic attachments are tiny.
Oct 10, 2008 | Bissell 3102-0 EasyVac Upright Vacuum
Roomba Discovery wiggles back and forth and turns over and over
No matter your model Roomba, this occurs when Roomba has gone "crazy." Its brain is no longer working properly and you can usually tell this when you've cleaned the dickens out of it a few times and the behavior is still the same. There's only one possible user fix and that is to take out the battery, hold down the power button for 20-30 seconds then reinsert the battery.
If that doesn't do the trick, IRobot might send you something called an Ozmo which you put in the data port to rewrite Roomba's brain. Unfortunately this requires it to be under warranty unless you get lucky. Good luck, all!
Jul 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Mint Evolution Robotics Automatic Floor Cleaner - Model 4200 Logo
35 people viewed this question
Top Mint Vacuums Experts
JoeVacs
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
