Question about Avaya 9611G
How do you keep the screen lit on the 9611g
I would like to be able to see the que at all times
Why doesn't my 9611G phone ring when someone calls
turn the profile to normal and the ringtone to a loud one. make sure the volume is up. ensure there are no diverts set.
You can reset to factory default and setup from scratch if you have difficulties locating the error
Jun 30, 2015 | Avaya 9611G
I have a Hyundai elantra Gt 2013. For the first time, the screen of the radio is frozen and won't shut off even if the car is. I went back to the car after 2 hours, and the screen is still lit. I'm af
I would located the fuse box and pull out the fuse for the radio. Keep it out for a minute then replace. That might reset the radio. If that doesn't work, maybe it's still under warranty.
Jan 10, 2015 | 2013 Hyundai Elantra GT
How to change exetension no in ip phone 9611g
If you have an ip phone i suppose you are in an office environment - please contact your system admin to help change the extension
Oct 23, 2013 | Avaya 9611G
Change time
You need to log in to the system administration. Unless you have a button programmed called "self administer". If you do, press that. If your system admin has allowed you to change the time, you will see a button labeled time...
May 22, 2013 | Avaya 9611G
On my dsi it keeps saying oooofefe on the top black screen can you help???
Yo tengo el mismo problema. El servicio técnico dice que es a causa de que se ha mojado la placa base, pero es mentira. Es un error de fabricación. Es una averia de la placa base.
Dec 25, 2010 | Nintendo DSi White Console
Screen will not stay lit
Check in the POWER OPTIONS section of the control panel if the display timeout for inactivity is too short. This is ONLY if the machine remains running.
If the whole unit is shutting down then likely your charger is not being effective. This problem can be with the charger OR the charging system on the motherboard of the laptop.
Apr 05, 2010 | HP Pavilion dv1000 Notebook
F380 keeps going off line
Are you sure you using a 2.0 USB cable? If not, try and get one. Additionally, try not to send more than one print commands at a time. Your Computers's virtual memory maybe low. So try working from that angle. Goodluck.
Jul 24, 2009 | HP DeskJet F380 All-In-One Printer
HOW DO YOU KEEP THE DISPLAY SCREEN ON LONGER THAN THE 60 SECONDS ON A LG CU VU 920.CAN YOU DISENGAGE IT?
some phones can only keep the display lit up for a certain amount of time all depending on the model and the manufacturer of the phone. and if it is possible to change it, it would be under Settings and then Display. if not then ur phone is just not capable of maintaning a lit up display for longer periods of time.
Jul 26, 2008 | LG Cell Phones
Avaya 9611G Logo
43 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
