Question about Epson Office Equipment & Supplies
Acetone gt7 I HAVE A ACE TONE GT7 CAN U TELL ME IF THIS IS A RARE PEICE
Why acetone will cloudy turbid when mix with water, is there any contamination?
What is purity of acetone? Is this acetone chemical grade pure?
Check also purity of water, you have use distilled water for solution. Water also should be degased, because if water contain dissolved gases mixing with acetone will form small bubbles looking as turbidity.
Sep 27, 2014 | Science & Laboratory
Dtc gt7 reset
How to reset DTC GT7 astroid max
Too Many Attempts..How To Reset?
Feb 03, 2014 | Cell Phones
DTC GT7
i fogot my unlock password of my dtc g7... i need help
Jul 29, 2013 | Cell Phones
Can I hook up my saltwater system to the 16 foot pro-series that has the filter mounted to the sidewall of the pool
you can go to ace hardware or true value and spend under ten dollars. you need a 1 1/4" to 1 1/2" flex drain & trap con.[ it is rubber and has two hose clamps on it] and a white pvc reducer 1 1/2" to 1" and a small peice of 1" pvc. you hook the 1 1/4" side to your pool pump then the pvc reducer into the1 1/2' side then you glue the 1'pvc [about a 5" peice] into the reducer the other end of the 1'' will go into the adapter it fits tight but it will go now you are ready to go
May 16, 2012 | Pool & Spa
How do I add my own text message tone to Galaxy Samsung Ace please?
I just thought this may help u for galaxy ace to add ringtones and notification tones..
Just create these folders to your SD Card and audio files are shown automatically to the ringtones and notifiaction tones. No application needed to add your favorite songs, tones..
Hope this will work for you
For Ringtones:-
SDCARD/ MEDIA/ AUDIO/ RINGTONES
For Nofications Tones :-
SDCARD/ MEDIA/ AUDIO/ NOTIFICATIONS
Jan 10, 2012 | Android Galaxy Ace
How do i change a ring tone to one that is in my song list on the galexy ace
There are two ways to get that done.
1. You get it done from your tone settings.
Go to the 'tones' sub menu.
Select the option that prompts you to change tone.
You would see the list of tones that came with the phone,
and an option to select from the gallery.
Select the option to go to the gallery.
Scroll to the song of your choice.
Select it.
Remember to select 'save / ok / done'. when you are done.
2. Go to that song in your gallery.
Select options.
Select the use tone option, indicating to use it as ring tone.
The second process is quite faster than the first.
Hope that was helpful?
Regards.
May 20, 2011 | Cell Phones
I am not apply the external ring tone in my samsung ace moblie , so please tell me the way ??
Connect your phone with your PC. Copy-paste the mp3 file into your phone's memory card. Plug off the cable data from your PC, open your phone's menu, go o gallery > music folder where you saved the file > click the file > option > set as ringtone.
Hope this help.
Feb 17, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to add a tone control to a Rare Earth humbucking acoustic pickup?
here is a diagram on how to add a tone control to humbuckers.
http://sthac.free.fr/pictures/sthac-HSH-wiring.jpg
for your set up, all u have to do is to do is wire the positive parallel form the pick-up or volume knob into the middle lead of the pot, wire the negative parallel to the casing of the pot, and put a .022- .033 ohm capacitor from the casing to the pot lead on the right, when viewed from the bottom. wiring parallel means "tapping into" the circuit, not rerouuting the circuit.
Nov 30, 2010 | Fishman Rare Earth Pro-Rep-102 Humbucking...
Samsung SPH-i325 Ringing Tone problem
It's possible that there's something wrong with your microphone of phone,just change a new one to try it
Jul 08, 2010 | Samsung Ace SPH-i325
12 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
