Question about Beko TLDA662
Swapping door side should the hinge be tight - Beko TLDA662
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
Tip
How do I change freezer door opening side?
Hi.
Details on how to change the fridge door opening side depend on the appliance model.If this is a chest unit, you will simply need to rotate the unit. On most upright units the general procedure to change door opening orientation is more or less the one ilustrated below:
  1. Disconnect power from the appliance.
  2. Get to the top side of the unit, and remove the hinge plate. This is usually held by two Torx or Philips screws. You may need to help yourself with a putty knife to remove a protective panel covering the plate. Be careful not to damage any part.
  3. Remove top hinge and put it on one side.
  4. After removing the plate you may need to remove the plastic clip located at the top on the handle side of the door, oppositely to the old hinge side. Use the putty knife to pry up and remove the plastic clip.
  5. Open the door and lift it from the lower hinge pivot.On many fridges you will have to remove the bottom hinge too, often held by two screws, and covered with a proective pane, to free the door before removing it
  6. Carefully place the door on the floor.
  7. Remove protective panels on top and bottom on handle side of the frige cavity, reinstall the hinges on handle side position, swapping them with the protective panels.
  8. Remove the door pivot and mount it on the opposite side.
  9. On the door disassemble and refit handle or any other part if needed.
The precise and complete procedure is usually illustrated on the appliance user manual. If you need manual or schematics, try asking a new Fixya question. Ensure that you are providing full model number, as printed on service tag.
To get more detailed info you can also try calling the appliance manufacturer at the number listed on the owners manual.
Regards.
on Mar 30, 2010 | Refrigerators
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
Hi, I have Frigidaire side by side doors refrigerator about 5 years old. refrigerator door knocks when when I close the door . Is that adjustment problem or some parts worn out and have to be...
It is probably a cracked lower bushing or loose lower hinge. If the hinge is tight, then the bushing is probably bad. It is not a hard part to change. Empty the door then then remove the top door hinge. The door should lift off the lower hinge and expose the bushing. Put in a new bushing, grease it a litte with some Vaseline or equivelent and reinstall the door. This link has an exploded view and part # of the bushing (#22 on the diagram). http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239787#d1239787
Hope this helps
Jan 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a 1995 dodge dakota. I need to replace driver side door. Need to know how to take door off properly. Need diagram or something. HELP.
Removal & Installation
  1. Matchmark the hinge-to-body and hinge-to-door locations. Support the door either on jackstands or have somebody hold it for you.
  2. Remove the lower hinge-to-door bolts.
  3. Remove the upper hinge-to-door bolts and lift the door off the hinges.
Details of a common door assembly-Dakota shown
Click to Enlarge
To install:
  1. If the hinges are being replaced, remove them from the door pillar.
  2. Install the door and hinges with the bolts finger-tight.
View of the door hinges-1994-96 Pick-ups
Oct 23, 2010 | 1995 Dodge Dakota
Refrig door does not seem to close as tight as it used too. Do I change rubber gasket? Will that help Frig is not very old.
look for door hinge problem as the door seal may be bad but i think the hinge cams have failed .. mm
Aug 09, 2010 | Maytag MZD2766GES Side by Side...
The refrigerator door side does not shut tightly. The gasket seems to be ok and we leveled the unit. Still not shutting tightly like the freezer side which seems to have a magnetic pull to assist close....
Check bottom hinge cam riser located on bottom hinge the pin that goes inside the door it's plastic it's a 2 piece part 1 part goes over hinge pin and the other goes inside door hole. They get worn and break. If you replace this make sure you get both parts until you do try adj. top door hing to get the door tighter.
May 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Door will not close tight
If it is a drop down door with hinges on each side, then it is the hinge springs that usually cause the porblem, as they become weak over time.
The only solution is to replace both the door hinges, as they are not adjustable.
Please rate my solution.
Thankyou.
Feb 01, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
I need to remove and replace my drivers side door and do not know how to do so.
go look at the passengers side. take note of the door seam and fender seam width. its about the width of a piece of cardboad. additionally look at the door hinges on the passenger side. it may or may not have washer shims. if they do/dont then just match up with passenger side. it takes 2 people to hang the door. screw in door hinges "finger tight" just to take off the weight of someone holding the door. play with the hinges until you can open/close door without binding or crimping fender at the seam. do not over tighten hinge bolts until the door opens/closes unobstructed. bottomline 2 people needed. slow and tedious job. you may have to add or take shims(washers) out for good fit. note that you may have to add shims to the inner door hinges or to the fender hinges where they meet. hope this is clear instructions.
May 30, 2009 | 2002 Pontiac Grand Prix
Beko TLDA662 Logo
13 people viewed this question
Top Beko Refrigerators Experts
AJMAL KHAN
ray gallant
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
