Question about Sony (DDU1613) (ddu1613black) Internal DVD Drive
My Dvd recorder simply says the dv/d8 device is not connected
2 Suggested Answers
maynagl
  • 10 Answers
SOURCE: I get an error message that says
It means that the DVD Recorder thinks that the DV or Digital 8 camcorder is not connected to the iLink / Firewire connector. Check you have everything connected properly or if you want to record a different way there may be a memory option that allows you to change the way the unit is expecting to receive a signal. The DV/D8 just means DV or Digital8 which are 2 standards in video recording with different types of tape. The specific interface here is an iLink interface specific to Sony to allow control of the recording interface remotely. It is also possible that your iLink or firewire connected device is not compatible with this Sony model....
Posted on Dec 14, 2009
Testimonial: "Thanks.I will check out these suggestions."
I just bought a sony DVD recorder, on input 3, it comes up "DV/D8 device is not connected". What is a "DV/D8 device"??? What can I do to fix the problem???
DV/D8 means Digital Video/Digital 8 which is a digital camcorder or digital 8mm format camcorder. If you connect this type of camcorder to the DVD recorder, input 3 is where it would connect but if you are not using a camcorder connection you can just ignore the message, its not a "problem".
Aug 13, 2010 | Televison & Video
Does my Sharp DV-RW34OU dvd recorder+vcr have microphone capability? If so can I purchase a compatible microphone online?
Ur Sharp DVD Recorder/VCR combo have any HDMI ports.Yes,Tries websites like Amazon.com,Ebay.com to buy a Digital microphone use the HDMI port it work fine.No tries researches buy the analog microphone.Just ask the vendors info.for the device functionable or compatible to ur device.
Jul 03, 2010 | Sharp DV-RW340U DVD Recorder/VCR
Can not record. When I press record I get a message " can not connect with the DV/D8 Device. Have never had any problems before recording
If you are recording from a digital video camera you should be using the DV-IN jack(that's why you get the dv/d8 error). If you are just trying to record a show from a cablr/sat channel then you need to select the correct input for the device you are trying to record from(vid1,vid2,dvin etc). you can download a service mnaual from sony.com if you are in need of one.
Feb 17, 2010 | Sony RDR-GX355
Dec 14, 2009 | Sony (DDU1613) (ddu1613black) Internal DVD...
I'm getting a message "Camcorder not connected. I can't program any recordings
When this recorder reads 'not connected to camcorder' you are simply accessing the recorder's 'DV' input on the front panel of recorder. This 'DV' input is used with DV Camcorders, thus the message.
Simply hit the 'AUX' button on the remote control to access the recorders other inputs. It will cycle between-TUNER>>AV1>>AV2>>DV.
Depending on what you want to access or view and where they are hooked up to the recorder. The "Tuner" will access either your over the air digital channels or your basic cable channels when hooked up through the 'UHF/VHF' input on the rear panel.AV1 is input 1 on the back of the recorder. AV2 is the input on the front of the recorder. DV allows for a Digital Video Camcorder to be hooked up to recorder using a 'Firewire'.
Oct 29, 2009 | JVC DR-MV100B DVD Recorder/VCR
Convert my canon es900 video to dvd
If you have a video card that has a video in port, plug in your 8mm camcorder and capture the movie. Depending on the quality you save it as determines the size of the file.
This is the simplest way in leiu of paying to have it done or "projecting" the image onto another media physically.
There are machines designed to do this of course but they're not cheap. If you know someone with a Digital8 camcorder. Sony D8 backward support V8 and Hi8, so you can just simply insert the V8/Hi8 tapes into the D8 camcorder, then transer them to computer in DV format through firewire cable.
Let me know if this helped
Dec 22, 2008 | Canon ES900 Camcorder
Panasonic NV GS 400 mainboard problem
What he probably means is that the IC that "Drives" the "Port' has been damaged or destroyed, a very common problem. Due to the manufacturing method, IE: Surface mount compnentry, there simply aint no "Simple Soldering problem" fix, at all... the actual IC, must be replaced... but this isn't actually possible..(well technicaly it is possible, but real hard to do) so hence the only other "Fix", a board replacement. Although ya DV outlet is kaput... If there is another output? say an A/V out? could you not use that as a work arround?
Aug 31, 2007 | Panasonic NV-GS400 Camcorder
Failed to record
Need to connect both the 3-prong AV adapter *and* the firewire cord. The firewire connect alone does not work, and the 3-prong AV cord alone does not work. But connect both cords to the two devices, and it seems to work. 15 minutes and counting... Hope this helps someone.
Aug 13, 2007 | Sony DVDirect VRD-MC3 DVD Recorder
Sony (DDU1613) (ddu1613black) Internal DVD Drive Logo
750 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
