Question about RTO PasLode 900420 Impulse Framing Nailer
Does not fire the nails when you pull tjhe trigger but the gas and fan still work
    Sniper:
  • 79 Answers
First, make sure you gas is not expired, it has a date on it. Next, Make sure your green light comes on. Take off the back cover with the allen wrench and two phillips head screws on the sides. Pull it out, being very careful and make sure when you put it back the wires are tucked in there place again. There is an o-ring under the fan that may need replacing causing the vacuum to not work.Also, make sure the little spark plug is clean of all carbon residue. Clean with some WD40 or ether. Worst case scenario spark plug or little o-rings way deep inside. You can find parts for these things. Lemme know. Please rate me
Posted on Jun 18, 2009
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
Paslode 16G finish nailer fires intermittently. Fan runs with each trigger pull but nail only fires about 1 out of 10 pulls if I'm lucky. I've installed a new gas canister so I know thats not the...
Clean it and oil it according to directions, then put a dab of dielectric grease on top of the spark plug. If this does not work ...Change the spark plug. I found one spark plug that had broken in half and made good contact intermittently which caused the problem you describe
Nov 27, 2010 | Craftsman Nailer Kit, Palm Air Driver
Quit firing nails motor comes on but nothing happens when pulling trigger
I am assuming that you have changed the gas cylinder. Make sure you have the exact correct cylinder, because there are some that look like they fit, but don't quite seal. This unit requires battery charged for ignition and induction fan. And it requires fuel to drive the nail,.
Oct 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My hitachi nr 90 gc nailer was always slow to fire a nail with about a second delay between pulling the trigger and firing the nail. now however the gun will only fire a nail once in about 20 attempts, and...
Trigger may be dirty, as an electrical switch the contacts can be intermittent. Also check to see if the safety plunger is set to correct depth and moving freely. Dirt can build up here......
Feb 14, 2010 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Nail Gun Problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Sep 01, 2008 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
RTO PasLode 900420 Impulse Framing Nailer  Logo
299 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
