Tank hols 14 litres water where you fill there is a indicator if that is clear the tank is not full has to be red to be full. The water fill symbol will then go out.
Your pump may be cracked or a drain hose may have a hole. Also check the dishwasher housing not the cabinet that you can see I have seen small holds due to defects in the plastic that the housing is made up of. Of time with heat and moisture these hols may appear. Look for small crackes in crevices. They are hard to detect once the cabinet is removed start the dishwasher and have flashlight to see exactly where water is coming from.
If you have anymore questions please comment me back.
If i am remembering correctly. There should be 2 screws on the underside of the cleaner that go through to the top. Also remove the sweep tail, the head float, and debris bag.
Try disabling the heater and recheck. Unplug each component to control pack to identify which is causing gfci trip. This will isolate problem units or controls.
you also have to remove the bracket that hols the caliper to the rotor. hope this helps. they will most like be an 18mm head for the bolts that hold the bracket. hope this helps.......please rate this
