Question about Vehicle Parts & Accessories
My 1996 gmc surburban that is acting up...i recently cleaned the engine ....yes i had the engine on but it started to act funny... it started to idle abnormaly...it would accelerarate for a while...it
So i tried to let the engine run...and i even drove it so it would get dry right...but it kept accelerating by itself...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
Check vacuum line you may have knocked on off when you cleaned it.
Posted on Mar 18, 2014
Testimonial: "where can i find the vacuum line?...and just in case if it wasn't the vacuum line what other thing can it be?"
  • Fidensio Ayala Mar 23, 2014
1996 Gmc Jimmy will not start new wires plugs dist. rotor act like it will start but does't
you are out of timing or you put your distributor 180 off or you may have hooked the plug wires up wrong you may have 2 in the wrong place
Apr 16, 2013 | 1996 GMC Jimmy
I have multiple misfire on my gmc envoy
The throttle body needs to be cleaned, grime in this area prevents the throttle plate from closing completely and allowing air to enter, making the air/fuel mixture lean. Make sure to clean the front and back sides of the throttle body. Also, disconnect the battery during the cleaning process to allow the computer to reset and relearn to the cleaned throttle body.
And, do not use any of those "gas saving" chips, they are a waste of money.
Oct 16, 2012 | 2003 GMC Envoy
Timming off on my 1999 surburban 5.7 vortic
These usually act like the timing is off and won't start from a bad distributor cap.
Sep 18, 2010 | GMC Suburban Cars & Trucks
1996 gmc sonoma idles high, i replaced the maf sensor but that was not the problem. this problem started after i did plugs cap rotor wires air filter. i have no codes on the obd but im still high idle.
check over that snorkle good, ive created vaccum leaks there before. look over it all and make sure shits plugged in of coourse. clean throttle and if its still acting up tap on iac and egr valve make sure theyre not stuck
Aug 22, 2010 | 1996 GMC Sonoma
I have a 1996 Acura 3.2tl. When I start it, the
If you can keep it idling after start,with your foot on a accel. pedal , then most likely your idle control valve is acting up.
Apr 29, 2010 | 1996 Acura TL Series
Dodge 1996 caravan/engine starts then abruptly shuts off
I would check the iac(idle air control valve) first it controls the idle, and then if it is still acting up you may have to change the crank/cam position sensor
May 28, 2009 | 1996 Dodge Caravan
Need drive belt diagram for 1996 gmc surburban
usually there is a diagram under the hood on the radiator core suport if not any napa that has michel can pull you one up on the computer
Mar 18, 2009 | 1996 GMC Suburban
Idle air control
all the sudden the check engine light came on and it started to idle funny and dying at stops. I had a diagnostic done on it and changed out the idle air control valve but it doent seem any different. and the check engine light is still throwing the same code. we adjusted the idle up so i could drive it with out it dying but it is still acting funny.
Sep 19, 2008 | 1997 Mitsubishi Galant
1994 dodge caravan, 2wd, 3.0 engine
12 - battery recently disconnected. 21 - Oxygen sensor signal doesn't change (stays at 4.3 - 4.5 V) possibly bad O2 sensor 37 - Transmission temp. sensor reading low.
There are many options that can cause these problems, but loose wiring to the battery and a weak alternator would be one of the first things to check.
Sep 16, 2008 | 1996 Dodge Caravan
Rough idle, steady idle of 1500rpm's when you crank, jerking down the road with idle jumping
1999 Surburban. Rough idle when engine is cold for about 3-5 min and then it starts to smooth out. Any ideas why the engine would act like this?.
Aug 02, 2008 | Chevrolet Cavalier Cars & Trucks
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
