Question about Miele DG155-1 Steam Oven Single
Temperature falls During the operation, temperature displayed falls 30-40 degrees, get back to 100 after a whiel
Oven 388-610 won't heat up past 100F.
Hello. I'm not familiar with your particular unit but if it operates like most other brands, the display doesn't show temps under 100 degrees. From what you're describing, the oven isn't heating at all. I would suspect either a defective bake element or, an open thermostat which cuts the electricity to the elements if the temperature gets too high. If the safety thermostat checks good, then the problem most likely is the main oven control board--which simply activates a relay to turn on the element.
Nov 06, 2015 | Gaggenau Ovens
My Kenmore 911-4298814 oven won't hold broil or bake temp setting. The oven powers on with no error. When I press the "Bake" and dial up a temperature to (say) 350 degrees, the LCD displays...
just had similar problem with frigidaire, temp display would go blank, not even show clock, i took off back of stove, the circuit board would wiggle. when i pushed in on the circuit board it worked correctly.
Oct 30, 2011 | Ovens
How do I change the temp fro m degrees C to degrees F? I have a Accubake System single oven. Thanks!
From Page 15 of the Manual:
Press and hold the "Custom Broil" pad for 5
seconds. A short tone will sound
NOTE: The temperature display will go off
and the temperatures displayed will
after a conversion. The temperature display
be converted. To switch back to "F, repeat the instructions above.
NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
Jul 16, 2011 | Whirlpool RBS275PD Electric Single Oven
Hi Experts! I'm having problems with my Ariston FO87CIX oven. The oven turns on but if I try to set the temperature the oven turn off and the time resets. It's weird but I've worked out that any...
One of 2 things, either the pt100(sensor) is faulty, or the control is defective. Unfortunately you need a digital multimeter to check the sensor first. When in doubt, replace both and all will be well.
Sep 09, 2010 | Ovens
Temperature varies
very normal but only during pre heat / once the oven is stable tempt should be 5 to 10 deg above and below the tempt setting and if not replace the oven temp sensor located inside the oven on the back ..mm
Jul 12, 2010 | GE JGRS14 Gas Single Oven
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
Electric oven will not maintain temperature. drops 20 degrees
Jump online & get the schematics for your oven.. You'll need to troubleshoot the bake circuit, which is comprised of 2 - 120VAC legs (240VAC is applied during bake). One 120VAC leg is from the DLB relay and the other is from the Bake relay. if either one is bad, or not energizing, you won't get any power to the bake element. (The bake element runs 100% of the time during the bake cycle. broiler only operates 25% of the time during bake) I have had luck re-soldering the relay leg nodes on the backside of the relay board, as they develop "opens" over time. The relays are designed for ridiculous ##s of cycles, so they're not *usually* bad.
Dec 23, 2009 | Amana AOCS3040 Electric Single Oven
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven 150 degrees off
hi . i can help.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Jun 23, 2009 | Ovens
    General electric spectra oven F2 problem
    Replace the temperature sensor.
    Mar 21, 2009 | GE Ovens
    Ovens Logo
    19 people viewed this question
    Top Miele Ovens Experts
    Paul Bade
    Dan Webster
    Dan Webster
    John
    Are you a Miele Oven Expert? Answer questions, earn points and help others
