Question about Gbc HeatSeal H425 Laminator
Jammed around roller
Laminated sheet did not come out the back. Wrapped around roller
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Clear a paper jam on 3330
When you say "release it from around the roller", do you mean that the page looks like it is wrapped around the roller? If so then the fuser will possibly need replaced. Depending on how skilled you are you could try removing the fuser and disassembling it to remove the paper but it may not be possible. if you decide to try be careful not to tear the "roller". It is actually a fixing film, a thin mylar type product with a nonstick surface. It is easy to damage it and then you would have to replace the fuser for sure.
Jan 04, 2013 | HP LaserJet 3330 All-In-One Printer
The roller that spins with little brushes stopped suddenly and no longer spins. I pressed the red little knob at the end of the roller but it doesn't fix the problem.
open up the roller area check to see if somthing got picked up and jammed into the rollers so that it can't work, a rock or a screw or you might even have a large amount of string or fibers wrapped around the shaft or brush keeping it from rolling
Feb 19, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
My OKI 5200 is saying it has a paper jam open front cover there is no paper jammed and i have looked everywhere for a problem and cannot find one. Still it won't print until the paper jam problem is...
Mine did the same once and although at first I was convinced it was the printer reading incorrectly, in the end, after opening all the parts that open up, I did find a sheet of paper wrapped around the rollers at the back.
Nov 17, 2009 | OKI C5200n Laser Printer
Paper comes out wrinkled on the left side. appears as if something is wrapped around a roller but can't see it
If you have ever used sheet label stock, you may have some residue of the adhesive contaminating a roller in the transport path or possibly bits of a label that didn't come out.
Oct 13, 2009 | HP Color LaserJet 2600n Printer
Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Jul 28, 2009 | Dell 1720dn Laser Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Transparency is stuck inside copier
The transparency probably melted to the the fuser roller (Did you use a transparencies sheet that was rated for use in copier?) Some copiers have a set function to allow transparencies sheets to run through. If transparencies is wrapped around the roller it maybe removed, but in most cases it needs to be replaced. If your in Maryland you can contact Innovative Copy Products if not contact your local copier dealer and they can help.
Oct 12, 2008 | Canon PC-940 Black and White Copier
Ribbon jamming in printer
i will simply advice you to pick another printer instead of the mother board because it might not be the only problem your printer has
Mar 06, 2008 | Olympus Camedia P-10 Thermal Photo Printer
Gbc HeatSeal H425 Laminator Logo
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
