Question about Polaroid 1511-TLXB 15.4 in. LCD Television
Black box in the middle of the screen - Polaroid 1511-TLXB 15.4 in. LCD Television
I have a black square box that resides in the middle of the picture. It is not the closed caption...is the TV toast or is there a chip replacement or some other fix that is not cost prohibative?
I would recheck the cc and make sure it is OFF. It has to be set to TEXT for the black box to be in the MIDDLE of the screen. Also make sure the MUTE is not on. There is nothing else that I know of that would generate a box in the middle of the screen, any other problems would knock out an entire section of the screen.
Feb 28, 2011 | Philips 47PFL7403D 47 in. LCD TV
Television hAs a black box blocking picture in the middle o he screen. when you hit volume the black goes away until the volume icon goes off
Go to ur tv menu.Go in captioning turn off all 1,2,3 and all txt will stop the black box in the middle of the screen.
Mar 26, 2010 | Toshiba 32A33 32" TV
Black box in the middle of screen
some one has turned on your closed captions
use your remote and turn it off
Sep 19, 2009 | TruTech KLV3112 10 in. LCD TV/DVD Combo
BLACK BOX ON TV SCREEN
check the closed captioning setting. I black box in the middle is one of the settings. Set CC to off.
Jun 02, 2009 | JVC Televison & Video
Get a black square box in the middle of the screen
Turn off your Closed Caption, it's in text mode.
May 30, 2009 | Insignia 37" LCD Flat-Panel HDTV
Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Mar 07, 2009 | Panasonic PV-C1322 13 in. TV/VCR Combo
Read the manual about picture in picture and turn it off. I hope this helps.
Jan 12, 2009 | Hitachi 32HDL52 32 in. LCD Television
Black mini screen in the middle of screen...
Go to the closed caption menue and turn off "text"... That's a text box and in most areas there is no feed so the black box is all you'll get...
Bill
Dec 09, 2007 | Hitachi 43FDX20B 43" Rear Projection...
TOSHIBA tv
I had the same problem. A big black box in the middle of the screen that would temperarily go away if with the EDS button.
Go to the main menu and turn off closed captioning. It worked for me! :D
Sep 09, 2007 | Toshiba 27A34 27" TV
Polaroid 1511-TLXB 15.4 in. LCD Television Logo
18 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
