Question about Toshiba Satellite A105 Notebook
Toshiba Satellite L35 Windows XP won't boot up
When trying to start my laptop, I get an error screen indicating that Windows has an error and I am given several options to boot - Use the last known working settings, Safe mode, Safe mode with networking, or start Windows normally.  None of these options work, I either get another error screen, or an attempt to a command prompt that hangs up, and then the computer shuts down and starts the cycle over again.
I have re-seated the hard drive and the memory, and neither solved the problem.  I would like to avoid using the Toshiba Recovery disks to avoid data loss. (I backed up everything but my photos and I'd hate to lose them if it can be avoided.)
Any suggestions?
  • Anonymous Feb 03, 2009
    I had the same problem and used the recovery disc and wiped it
    clean. Worked for a few day then same thing happened. Any one
    know the solution?
  • 143 Answers
Well you might have to redo your hard drive sounds like some files in the operating system are corrupt go to your nerest computer place ask for addapter to connect your laptop hard drive to your pc then try to scan hard drive pull pics out then format harddrive
Posted on Nov 03, 2007
"how to clean & install toshiba satellite l35-s1054 win 7 "
Look in BIOS during reboot, make sure the hard drive is detected. Run hard drive test and memory test. Use BIOS feature to setup boot options and boot order, set all to default. Reboot.
Feb 10, 2013 | Toshiba Satellite L35-S1054 Laptop...
I need the video driver for my toshiba satellite l35-s2366 laptop for windows xp
This driver should do the trick for you as the video on your laptop is a ATI Radeon Xpress series GPU.
Robert from Blitware
Jun 11, 2010 | Toshiba Satellite L35-S2366 Notebook
Can't get into BIOS on my Toshiba Laptop
No manufacturers password that I have ever heard of but you can remove your keyboard and disconnect the mother board (BIOS) battery. Leave it disconnected for a few minutes. When reconnected the password should be gone. A few laptops actually have a jumper to do this.
Mar 29, 2010 | Toshiba Satellite L35-S2366 Notebook
I have the toshiba satellite L35, when i turn it on the red toshiba logo shows up but then after that it goes to a black screen that says a disc read error occurred
you may have lost your hard drive. always best to back up your files and os on an external drive. if you have a recovery disc try to boot it
Dec 16, 2009 | Toshiba Satellite L35-S2366 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Media drive not found my laptop is toshiba sat a45 s150. after turning it off unsuccessfully, a blue screen error was displayed. if long pressed the power button to shut it down. after opening it again,...
Most likely the boot sector is corrupt.Try to boot by starting the Computer and hitting F8, or F12 you need to get to your start windows splash screen.Then try Start Windows from Last Known Good Configuration.If that don't work try Safe Mode.If none work you will need to recreate your .boot file, or try recovery fron CD.It gets complicated explaining how to rebuild your boot sector,If you have access to internet search "how to rebuild boot sector Windows XP".There are programs you can download and then load/run to rebuild boot.This has happened to me or someone I know and it is a pain to fix.You need some knowledge of how boot loads and how to repair.Try to get someone you know to help you.The problem was caused by the shut down.I think you ment XP can't Boot.Good Luck
Sep 11, 2009 | Toshiba Satellite A45-S150 Notebook
Unmountable boot volume is an error you get when your hard drive is failing. You will need to replace the hard drive.
May 21, 2009 | Toshiba Satellite L35-S2366 Notebook
Toshiba satellite laptop comes on and stays at windows xp page
If Safe Mode doesnt work then you may have to do a "repair" of your O/S. Place your Windows XP CD into the CD-Rom drive, reboot and once you see the options if you want to Install or Repair - choose Repair. This option will make repair to your O/S and for safe mode.
Once repair is complete do a complete Anti-Virus and Spyware scan of your Hard Drive. If you can boot into Safe Mode to run the ani-virus much better.
Dec 28, 2008 | Toshiba Satellite L35-S2366 Notebook
Toshiba Satellite A105 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
