Question about Zebra LP 2844 Thermal Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
    Scholar:
  • 62 Answers
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Posted on Dec 04, 2009
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
Printer is paused alert ribbon out after scrolling out rolls of ribbon, any attempt to re-align ribbon failed so far. Which printing mode should I be? print jobs make attempt to print but goes back to...
Locate your printer driver under devices and printers Right click on it and select "Printing Preferences" Choose the "Advanced Setup" tab Change media type to "Thermal Transfer" Be sure that "use printer settings" is NOT selected at the top left Click OK and you should be good. Note that any labels created prior to this change will need to be changed inside each label under the label setup.
May 18, 2011 | Zebra S4M Thermal Label Printer
I changed the ribbon to the monochrome R3012, but the printer has the NO RIBBON light on and it won't recognize it. I set the printing references to that ribbon style, the ribbon is not torn, I have made...
You may have installed ribbon incorrectly.
Align the gears of ribbon spindle with gears on printer and second important thing is that ribbon should come from up not from down.
Mar 13, 2011 | Evolis PEBBLE 4 Led Card Printer
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
The printer breaks the silver hologram ribbon everytime i print.it only break the silver ribbon when i do holograms
If your ribbon is breaking while printing a card, there area few things to look at.
  • Check that the printer driver has the appropriate ribbon selected. If a different ribbon is selected on the driver other than what you are using in the printer. Go into the driver and change the setting to the correct ribbon.
  • Another reason your ribbon may be breaking is because the "X" offset is set too low or too high, in other words the printing is beginning too close to the left side of the card, or ending too much to the right side so when the print head goes down to print on the card, the ribbon gets sliced because the print head and the edge of the card knife the ribbon. In order to eliminate this problem, increase or decrease the "X" offset value. I recommend a minimum of three digits up/down depending on the circumstance. For example: X-offset = 06...increase X-offset to 09. If the "X" offset is to high...EX: X-offset = 20...decrease X-offset to 17. Do not increase or decrease the value by more than 5.
  • If ribbon appears melted onto card, the print head may be damaged. Do not try adjusting. Immediately contact your re-seller or Zebra technical support.
  • If ribbon is breaking and nothing is being printed onthe card, contact your re-seller or Zebra technical support.
Dec 04, 2010 | Zebra P330i Thermal Card Printer
Won't print
Reset the printer to factory defult
May 04, 2010 | Zebra Z4Mplus Label Printer
RIBBON BREAKE
Several things can cause a ribbon to break. Let's start with the simplest - cleaning. Use your cleaning kit to clean the rollers and print head. If the rollers are dirty, cards can slip and cause ribbons to break. Another is the TOF setting. If the print image is too close to the front edge, the ribbon will break.
Check these 2 things and see if this helps!
onlineidtech
Feb 23, 2010 | Fargo DTC-300 Thermal Card Printer
I have not used our cannon s900 printer for a long time. I have just put all new ink tanks in and am not able to get any thing to print onto a page. the paper goes through ok and everything sounds ok. will...
these printers have a printhead seperate from the carts....therefore the ink in the lines and the printhead are very succeptible to drying out...if you haven't used the printer for any amount of time, it is very likely that there is coagulation in the lines....and in the print head...if you are dead set on keeping this printer, let me know and there are some other steps to try and save this printer....
Aug 09, 2009 | Office Equipment & Supplies
Printing problem
Try to clean the light sensor inside the printer, you will see a white led on the top part of the case, match it to the bottom you will see a small hole on a plastic peice, that is the hole for the sensor.
Oct 29, 2007 | Zebra P210i Thermal Printer
Zebra LP 2844 Thermal Printer Logo
173 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
