Question about Tricity Bendix AW1000W Front Load Washer
Wash cycles Length of washes
The washing cycle of my w13g701is too long how do I shorten the machine cycle
The length of washing cycle is programmed within the wash method.
Aug 29, 2017 | Washing Machines
How do you adjust length of washing programme.
Change the wash settings and the cycle time will change along with the options. Most machines have a 'quick cycle' to shorten wash time, or you can choose "heavy" and "pre-wash" to make an extra long cycle... Depends on the model.
Apr 25, 2016 | Washing Machines
Wash cycle takes too long
If the incoming water is very cold it takes longer to heat
this extends the cycle length
Sep 20, 2014 | Bosch Washing Machines
Cycle Running Way too long
Necessary to check the temperature of the heating of the water at laundry.
If all OK, - check the timer CPU -(X,tall).
Nov 12, 2013 | Indesit W 123 Front Load Washer
Washer
Each letter has a cycle length, the bigger the gap the longer the cycle, So it depends on how long you want your underwear washed for, If it is a short cycle turn the dial to the letter with the short cycle and turn it on! Hope this helps.
May 28, 2013 | Washing Machines
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
Why has the length of wash cycles increased?
You probably have an issue with the electronic control board.
Feb 26, 2010 | Dishwashers
Tricity Bendix AW1000W Front Load Washer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
