Question about IBM ThinkPad R51 Notebook
Where is numlock on 0301 keyboard - IBM ThinkPad R51 Notebook
My lenovo g530 laptop keyboard u,i,o,j,k,l buttons is not working properly if i am pressing those buttons 1,2,3,4,5,6 numbers is coming how to solve
you have numlock enabled which makes those numbers come instead, turn off numlock on your keyboard. please read your usermanual on how to use the keyboard to turn off numlock. it is a numlock button or a combination of buttons that needs to be pressed.
Jun 30, 2012 | Lenovo Computers & Internet
Some key on the keyboard are typing numbers instead of letters what should i do please?
You might have accidentally activated the "Numlock" key on your keyboard. Just press the Numlock and it should type in letters instead of numbers.
If press just the Numlock key will not work, try the combination which is CTRL and Numlock simultaneously.
Hope this helps.
Jun 17, 2011 | Tablets & eReaders
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
My computer keyboard is typing numbers instead of letters.. any suggestions on how to fix it
This is because most notebook keyboards have a number pad incorporated into the right-hand side of the keyboard. Numbers are being typed because the NumLock is active.
To disable this function press the NumLock key (might be marked NumLock or have a symbol that looks like a calculator on it) on the keyboard (you might need to press the Fn function key and the NumLock simultaneously).
http://www.pcdoctor-guide.com/wordpress/?p=2446
Nov 25, 2009 | Compaq Presario 700 470024-192 Notebook
Can't seem to unlock numbers.. tried FN key and nothing there is no numlock key
There is no NumLock key on that keyboard. But you can switch it off by accessing the Windows on-screen keyboard. XP - Start - all programs - accessories - accessibility - on screen keyboard. The keyboard appears on screen with a NumLock key. Vista - smiliar commands to get the keyboard up.
Oct 23, 2009 | Logitech Cordless Desktop MX 5000...
Numlock unable
hi,
try to press Fn Nmlk key on the keyboard,thats how you disabled/enabled numlock,if nothing happens,theres a possiblity that the problem is with the keyboard itself...contact manufacturer to have the keyboard replaced...
thanks
Jul 07, 2009 | Gateway 2520915 Keyboard
I have an Asus X59GL Series laptop... one of my friends just hit some command and now my keyboard is ****up! i have to hit the Fn key to type the letters uiopjklm;0... any help?
You have enabled NUMLOCK
Look for some text marked NUMLOCK in a colour similar to the fn key and hold fn then pres numlock.  SHould be fine after that.
Feb 24, 2009 | ASUS 90-A4C1K1000 Keyboard
Numlock
well, I have the same problem too, but finally I can fix this problem.
It's just very simple.
Can you see the OFFICE button, right on top of the F8 button and also on top of numlock green light (who is turned on if the numlock or caps lock active) ? Just press that button, then press the numlock button. Gotcha! The numlock light is turned on, right? Try to type some number on notepad with right side of your keyboard now.
Is this information helpful? Thanks before
Aug 03, 2008 | A4tech KBS-2680RP Keyboard
Main keyboard
The kkkkkkkk problem will be a sticky key, possibly something jamming the contact under the key.
The p* problem is your numlock is on. Laptop keyboards don't have numeric keypads like dsktops do, so when you press numlock on, it uses part of the keyboard to emulate a keypad.
You will probably have to press something like shift+numlock or ctrl+numlock or FN+numlock to release it. There should also be a light at the top of the laptop to indicate it's in numlock mode.
Apr 16, 2008 | Gateway 400SD4 Notebook
IBM ThinkPad R51 Notebook Logo
122 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
