Question about Dell Vostro 230 PC Desktop
Cap lock screen
How can we know it is in upper case?
Make lower case letters upper case
Shift for one letter, Caps lock for all caps. Lower right and left of keyboard on most computers.
On I phone, there is an arrow on the lower left - tap once, it will turn dark, and will cap one letter. Double tap, and it will use all caps, until you release by tapping again.
Aug 09, 2017 | Computers & Internet
Does this typewriter come with Code Cap feature?
I am sorry to tell you that your machine does NOT have that function.
This is the difference between Shift Lock and Caps Lock.
1) Shift Lock is the traditional upper case used since the oldest mechanical typewriters
2) Caps Lock (what you want) works like a computer, where you get upper case letters and numbers.
Brother does include this feature on some models, but I am sorry to say not yours.
If this helps you, PLEASE log back on to this webpage and leave comment. It's nice to know that I am helping someone and not just wasting my time.
Ron
Nov 03, 2011 | Brother SX-4000 Typewriter
Is there supposed to be a caps lock indicator on HPw2207 keyboard,? If there is, I must be missing something I can never tell if I am in upper or lower case letters ( not too good when entering a password)
That model goes to a LCD monitor, not keyboard. Windows can make a tone when you hit the cap locks, so you can use that as indicator or you can use the on-screen keyboard which should visually show the cap locks being pressed.
How to tell when you hit the cap locks key
Windows On-screen keyboard
Mar 25, 2011 | Computers & Internet
WHEN YOU PRESS THE CAPS LOCK BUTTON YOU HAVE THE CHOICE OF UPPER AND LOWER CASE LETTERING BUT THERE IS ALSO AN ARROW BUTTON WHICH IS TURNED OFF AND I AM NOT ABLE TO TURN IT OFF IT SEEMS TO HAVE REVERSED MY...
That UP arrow refers to an UPPER CASE letter. If ever you press the CAPS LOCK key, it should turn off, if it does not it means the CAPS LOCK key for some reason is stuck. Try restarting the computer and by then the CAPS LOCK should be disabled.
Please let me know if it helped by selecting YES. Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 31, 2011 | Gateway 2520915 Keyboard
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
How can you know when you are in upper or lower case
I have a feeling there are two ways to tell. First, the receiver unit that connects to your computer should have two LED light on them. One will have an "A". This will be lit when the Caps Lock is on. The second LED has a "1" over it, and that's your Num Lock indicator.
The second way will be after you install Logitech's software, text will appear across bottom of your screen (usually in green) for a second or two telling you if you just pressed the Caps Lock or Num Lock buttons.
Aug 25, 2009 | Logitech Cordless EX 100 Mouse
Keyboard stuck in upper case
press caps lock and F9 together see if that fixes it
May 06, 2008 | Microsoft Windows XP Home Edition
Dell Vostro 230 PC Desktop Logo
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
